How to shop for an intake
JennaBear
Resident Ninja
San Diego, CA
There are three different types of intakes:
Closed Box (ie. Volant, Outlaw)
Open Element (ie. AEM, K&N FIPK)
Drop In filter (ie. K&N)
When looking at manufacturers claims, one shouldn't just look at the HP numbers:
You need to look at the highest average airflow which is directly related to torque (subsequently HP).
Manifold pressure (MAP) is a measurement of restriction, the higher the number the less restriction, so this is another big point.
IAT (Intake Air Temp) recovery is another big factor in narrowing down a good intake.
Closed box intakes do better at lower speeds as there won't be as much of a heat soak issue. The open elements use metal shields which absorbs heat (heat soak).
The open element intakes drop temperatures a lot quicker at higher speeds which in turn creates denser air. The denser air allows for more airflow, which then of course makes more power.
This all being said, intakes (as well as exhausts) are a matter of personal preference, just taking off the stock tube takes off a lot of restriction. Realistically, the differences between intakes (ie. open vs. open and closed vs. closed) will be minimal. One thing I do encourage anyone who purchases an aftermarket unit to do, is check the fitment every couple hundred miles, these things find a way to wiggle loose and can cause a drop in performance as well as MPG.
Sepiroth
I am here
Kouts, In
I think Jenna typed it perfectly. It really, in the end, tends to come down to personal preference.
tybardy
everyone needs a Hoe
Gilbert Arizona
yes, personal preference... yessssss....
JK also has an off brand intake that Justin said performed VERY well... I have a makeshit setup using an aftermarket intake tube, drop in filter and some extra holes drilled... this was the cheap route for me and based on the numbers i have seen in the past was enough performance for me and saved me well into the $150 range.
I will say the fitment is an issue, i believe it is STILL an issue with my airraid tube fitting properly, Justin found an "issue" at my throttle body that we never hammered down and i believe it was the intake tube not adhearing well to the TB...
Volant1
Volant guy
Upland, CA
Outlaw is no longer around but S&B offers a closed box system and AFE and even K&N are starting to close up the filters hmmmm I wonder who started that trend lol good right up
Denali---LQ
i like my volant ... i was not expecting the sound to be as loud as it was ... but still a great system
jmildoc
Indianapolis,Area
i do agree about fitment, i have had to tighten mine down a couple times. but it seems to be fitting better an better as the rubber just forms the way it needs to... I wouldnt have had it any other way. plus i saved $240 and still gained a little pep and a little over 1mpg... Cant beat that!!!!!!!!!
TheFuzz
Idiot Police
Spurbury, VT
I'm just got a hold of Max today and told him to put me down for an AEM Brute Force - I'll be picking it up on Tuesday :D.
Too bad AEM got bought out by K&N...Max's price on the intakes have gone up quite a bit. BUT, that being said, he still gives a hell of a discount to us. His price, even with the increase, is still about $50-$60 cheaper than the closest competitor.
I'm putting it on as soon as I pick it up Tuesday, then on Friday we're driving to CA from Denver. I'll be interested to see what kind of seat of the pants gains I get with it since I already have my tune done. Hopefully I'll get a little bump in fuel mileage too. Best I've gotten so far is 18.8mpg on an otherwise stock truck thats leveled front and rear running 285s. Pretty impressive in and of itself, but I'll keep everyone posted. If I can squeak closer to the coveted 20mpg mark, I'll be thrilled.
coopiesb
wichita falls, tx
just got my aem the other day but its sitting it in a box in my living room.... mom is making an appointment to go get it installed
tybardy
Gilbert Arizona
If you have a flathead screw driver and a few other basics, you can do this job yourself in 30 minutes!
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
yeah ive installed a couple of them but hard to do when im 20 miles south of baghdad in iraq hahahah
man i hope she's not paying anyone to do that install. you're like a little kid in a candy store...lol. just can't wait til ya get home to install it...lol! I'm lovin it! Hopefully she tells the installer it's for an away active duty personnel and they just throw it on for you at no charge!
coopiesb
wichita falls, tx
hahahah yeah i cant stand stuff just sitting there its killing me......well the first place i went to was going to charge me 100 so were trying another place... i still got lowering kit, double din, corvette servo, efans, and theres something else i think
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
save the money and just put the cai on yourself...just hate to see someone rob you for a c note for a cai.
coopiesb
wichita falls, tx
yeah i know but its like eating me inside to have it sitting in the box in the living room...... my mom did put on my shortie anteana so thats a plus i thought she could handle it..
Max
Mile High
Denver
Love my aem, showed lower iats than my buddy's afe on his 03 tahoe when we datalogged.
Modded
That Guy
I'm torn b/w then Volant intake and the AfE 2 CX kit for my 07.
The problem here is neither have confirmed HP gains, so I want to makesure it atleast sounds good so I don't feel like I was ripped off if power expectations are not quite as stated.
The AfE kit I think is an exposed filter so it may be louder??
Can anyone help, JennaBear?
JamesinAbilene
