How to install steering wheel controls in your 95+
95BlackTahoe
Edinburg, PA
I decided that I loved the steering wheel radio controls that were in my sons 99 blazer, and since we are trading it, I decided to experiment. I have heard it several times that it wont work, but I wanted to try it. It does work...
This is how to install this nice feature into your OBS that didn't have this option...
You will need the following tools:
4mm socket 7mm socket and driver
#20 and #30 torx bits and driver
Small tipped snap ring pliers for external lock ring.
Small screwdriver, and or hook tool.
13/16 or equivalent socket, short extension and ratchet.
Steering wheel puller
You will need the following parts from an s-series (truck, blazer, jimmy, or bravada) preferably of the same model year:
1. Steering Wheel from 98+ S Series with airbag, button came in black or grey.
2. The clock spring from the same vehicle/year model.
3. Basic hand tools like sockets or wrenches, torx head screw drivers, wire strippers/crimpers , butt connectors, zip ties, and snap ring pliers.
4. Steering wheel puller. Can be bought or rented from your local AutoZone.
The vehicle must be off. Set the emergency brake and observe all precautions for working on the vehicles electrical system. Remove the SIR fuse from each vehicle you are working on, unless its in a junkyard and use precautions for working with the vehicles air bag (SIR). I shall not be responsible if you goof and the air bag removes a body part. Play it safe and pull the fuse, or even disconnect the battery. On 98+ S Series models this is 15 amp fuse located in slot 16 of the fuse panel. On the Full size , at least in the Suburban it was fuse 10. Wait at least 30 minutes for any stored energy to dissipate from the system.
Start by removing the air bag module. On the back side of the steering wheel there are two slots to access the spring that retains the two module retention pins. These spring clips need to be pushed to the center to disengage from the notch. Easier said than done. Older large bag wheels have I believe 4.
Carefully pull the retention clip and connector from the back of the air bag module. Place it aside in a safe place. Treat it like a bomb.
Remove the steering wheel retention nut. Install the gear puller and pull the steering wheel. Be sure to release the horn connection. It is the white plastic piece with the two red wires.
Next we will work on the column. Pull the tilt knob. The small screwdriver will help get it loose. Remove two #20 torx screws from the lower half of the cover and tilt it down. The lower half attaches to the upper half with hooks at the bottom. Don't break them. Now you have access to the 4mm screw near the ignition lock cylinder that retains the upper half of the cover.You will not need to remove the upper half completely.
Now you can remove the snap ring and the clock spring.
Under the dash on the drivers side, remove the black plastic panel where the OBDII connector is mounted. Remove the knee bolster. Cut the zip ties that hold the wiring in place and disconnect the yellow connector for the SIR harness. You will need to remove the orange safety retainer, simply pull it out.
This is the standard no controls clockspring. It only has the single yellow wire. I have heard you are supposed to reset this, but if you remove it carefully, and don't play with it, it will be fine.
Re-install the new clocksping, it will have a extra wire set on it, in gray. Once that is in and the snap ring is back in place, just feed the wires along the wiring harness along the column, and wire tie. Hook the air bag plug (yellow) back in and re-do the safety clip. Then simply install the wheel, and re-hook the horn, and the radio wiring in the wheel.
Re-install the Air Bag, simply by hooking the yellow connector to the bag, and pushing the assembly on the wheel until it clicks in place.
Now, You will still have your gray wires. Simply cut the plug off, as you will not need it, and strip back the gray wire cover. Inside that, you will find 4 wires. A yellow, black, green, and gray.
Here are the connections...
yellow wire = 12v switched (hot with key on)
grey = dash lights positive (makes the buttons light)
green = wheel signals to the new PAC SWI-X unit.
black = ground.
Simply use your butt connectors and wire it all together. Make it a nice clean job. There are a lot more wires on my Suburban than you will deal with because my truck has the audiovox drop down TV/dvd unit.
Here is the PAC interface I got. I picked it up on EBay for 19 bucks.
Program it as per the instructions, then tuck it away. Don't bury it though, as if you ever have a dead battery, you may have to re-program it, but I am not sure. I made mine easy to retrieve if needed.
All done, and it looks great.
and it really works!
All told, if I would have been able to work straight through with no interruptions, it would have been complete in 3-4 hrs. But, on that note, I did both vehicles at one time, so if you don't have to replace the other one, it will be faster.
Next...the trip computer...
Shawn
Dazrin
Awesome! My radio is going out on my 98, so I may have to invest in a new one...this might go with that.
95BlackTahoe
95BlackTahoe
Edinburg, PA
I installed the LED for the SWI-X in the dark grey section of the bezel, just to the right of the radio. My JVC does not have a remote connection, but uses infrared instead. I just kept it about inline with the sensor on the radio. worked out really well. When I do it to this Tahoe, it may wind up in the overhead console. In any event, the SWI-X led has to have a clear shot of the front of the radio for it to work properly. Keep that in mind when you mount it.
Shawn
95BlackTahoe
95BlackTahoe
Edinburg, PA
I never tried it, but I don't see any reason it wouldn't if the column hasn't changed, and come to think of it, I don't believe it did.
Shawn
Tballew27
Seattle,WA
well done!, definitely something Im gonna do, only thing is how hard it is to find the controls. Could these be bought through the dealer?
95BlackTahoe
95BlackTahoe
Edinburg, PA
The controls are easy to find. Look in the junkyard for high end s series blazers, 95 up, or Jimmys, or to be absolutely sure, Olds Bravadas of that same years had them standard.
Shawn
GMCjj
Holt, Mi
Nice write up!! I wonder if this will work on a 00-02 NBS.
Sorry I don't mean to threadjack but I did this mod on my 2000 Sierra, the hardest part was trying to find the damn clockspring that would work. I got one from a S10 Blazer but it doesn't match up plug wise with the NBS plugs. You need one from a Denali or Escalde.
95BlackTahoe
95BlackTahoe
Edinburg, PA
You aren't threadjacking at all.. glad to know this bit of information myself because my son has a 02 Sierra and guess what he wants dad to install...lol
Shawn
CherokeeWarrior
Great thread. Thank you
I want to do this soon also. I'm planning to build a custom in dash ipad2 station. This steering wheel upgrade will just sweeten the mod.
I have a question on the wiring. Do All the audio controls pass electric signals through one wire? From your instructions it looked that way to me.
Again thanks for this great post :)
varminpoolteam
