Blown Bose speaker
neloms
NorCal
I've got the Bose stock system in my 2005 rig and the front driver door speaker is blown. Is this an easy swap or am I going to have to cut out the speaker, splice wires and use self tapping screws to install a new one? I'd change both front speakers at the same time...
Timmy
Brunswick, GA
you should either replace all the speakers or go back with bose. it'll prevent a lot of headaches...
JKmotorsports
Austin, TX
If you do replace them with aftermarkets, you'll have to mount them with self-tappers. The "true" speaker size is 6 3/4", but any 6 1/2" will do. Some companies make the oversized GM 6 3/4" sizes though. For the wiring, you can buy speaker harness adapters that will plug into the stock speaker harness. You can get these at your local stereo shop or Best Buy.
One more thing, the Bose speakers are two ohm, whereas most aftermarkets are 4ohm, so you may notice a slight difference in output.
JKmotorsports
Austin, TX
JKmotorsports
Austin, TX
Yea, that's kinda weird. The only thing I can think of is that he may have been screwing into a harness behind the panel when he was mounting his aftermarkets.
blueflamed03
Oklahoma
and you can add a seperate subwoofer to the factory Bose setup as well...(contrary to what is all over forums)
neloms
neloms
NorCal
Have you seen a DIY thread on that install? I'd love to do that as well. Thanks for all the input, guys!
Tahoe03mm
Puyallup, WA
I had the Bose, I just bought an add-an-amp harness and tapped into existing sub leads and installed my own turn on switch(you could easily tie into something that uses accesory turn-on as well I'm sure).
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
I had bose and put polk speakers in place of the bose with stock everything else. Worked fine. Sound even better now with a complete system.
tom q
Modesto, CA
I'm changing my front speakers right now... I'll let you know what happens
neloms
neloms
NorCal
Thanks for the tips! I found some Infinity Reference speakers that are two ohm, I might buy four of those and do all the speakers at once...
JamesinAbilene
