still more questions regarding my rear end drop... help
Modded
That Guy
Dude thats perfectly fine having both, I was gonna tell you to do that.
But if you do, makesure the drop shock is for rides 2-3" and not 5", as 5" is way too small for use with extenders.
tybardy
tybardy
everyone needs a Hoe
Gilbert Arizona
so if i use the 1" extension i have w/ a set of these
http://www.stylintrucks.com/parts.a...cks&canned_results_trigger=&partfamilyid=1883
you think i would be doing allright??
i know this is rediculous, i just dont know shit about suspension... first timer here, im a motor person
BlizzardX23
Sacramento, California
I know you guys have posted the link to it...I gotta go back through my threads and find it..but
the "free travel mod" is just... cutting the rear bump stops out and installing the new shorter ones?
I know the bump stops apparently bounce the vehicle back up...but it still seems like the truck sinks to far down while hitting dips regardless of how hard its pushed back up?
This is only my uneducated beliefs...you guys are the smart ones in these sections...Im just learning
Max
Mile High
Denver
You don't need drop shocks and the tech is being a douche. You drive a 5000+lb suv the shit is not popping out...trust me I would know.
Grocery Getter
A guy with a truck.
Phoenix, Az
You cut the entire bracket that holds the bump stop off with a sawzall or plasma torch......It gives you stock travel. I have the McGaugy's shocks and they are fine but then again I haven't tried any other shocks. You can install smaller bump stops on the frame after you cut the brackets. I didn't but I don't run my rear seats, spare tire, or tow hitch and I rarely have anyone besides my daughter in the back seat so bottoming out is not an issue. If you have weight in the back and a bunch of knuckleheads riding around with you I'd order a set of shorter bump stops, they mount right to the frame.:gayflag:
tybardy
tybardy
Gilbert Arizona
sweet, would you recomend me adding drop shocks and extenders either way?
Max
Mile High
Denver
No need for drop shocks until you lower it more, I'm running the bilsteins which are 1/2" shorter than stock with my 5"ish drop and belltech shock extensions...no issues and I drive the hell out of my truck.
BOSS
The People's A D M I N
Dallas
I won't say I told you so on buying more expensive shocks from the get go. :)
BellTech 2412FF .....FTMFW :whymewhyme:
Max
Mile High
Denver
They are the same shock I'm running, and can be had for much cheaper than that. PM me before you buy some.
tybardy
tybardy
Gilbert Arizona
and the hits just keep on coming...
purchased some shock extenders from a local company in mesa and the holes don't line up!!!!!!!!
the truck gods sure are pissed about me lowering my truck! cant catch a break to save my ******* life!
so i am working with the company to get the correct brackets... and probably going to take the truck into that alignment company 'Getter and Chistoso use to get the job done RIGHT!
man i feel like a ***** for having this much trouble lowering a GD truck
veteran111
