tips to adjusting front bumper
tybardy
everyone needs a Hoe
Gilbert Arizona
notice the gap at the front bumper? does anyone have any tips for closing this gap up and lining it up better?
---------- Post added at 12:32 AM ---------- Previous post was at 12:25 AM ----------
here is another picture of the gap
tast101
Colton, CA
You can take the bumper off and use washers to raise the bumper. I'll find it for you, I was just looking at it last night.
---------- Post added at 08:24 AM ---------- Previous post was at 08:19 AM ----------
To start, I'd have to say I was given advice on quick fixes on how to do this but I decided to take my bumper all apart and figure out what the problem was with its leaning issue, and then make a fix that would last.
*All images can be enlarged needed.*
This is how my bumper looked earlier today. The driver side is quite noticeably sagging and I just could not stand leaving it that way.
So I started the tear down. First pop out the plastic pins on top of the grill and then pull the grill forward (it just pops out, no unscrewing)
Grill snapped out.
To take off the bumper, there are six bolts you must remove. I have vaguely circled their location in red.
Make sure you have unhooked anything on the bumper such as fog lights and
slide the bumper off. I strongly advise you place something on the ground in order not to scratch your bumper (I used towels).
I have circled four brackets on the back of the bumper. The two red ones were on the leaning side and need adjusting while the green brackets were in the correct position.
To access the bolts, I took the upper and lower valences off (I will call them valences for now in lack of remembering the correct name) For the upper valance, I used a wrench to squeeze each clip and push them out of the bumper. For the lower valance, I removed the fog lights (2 bolts each) and then unbolted and unclipped it from the bumper.
You should end up with this.
After loosening the bolts on the bad side, I placed the bumper back onto my truck. I leveled the bad side with the good side, and tightened the hell out of the bad side. After measuring and remeasuring, I was able to even out the bumper.
After making sure the bumper was just how I wanted it, I pieced everything back, bolted the bumper back on to my liking, and took a picture of the turn out. (it's kind of hard to tell from the bad picture but everything measured up.)
http://s42.photobucket.com/albums/e340/Yukhui/Bumper/
I have all of the pictures and some extra posted on my photobucket ^ if you'd like to check that out for better pictures. Hope you guys found this useful, enjoy!
http://www.gmfullsize.com/forum/showthread.php?t=151096
http://www.silveradoss.com/forums/index.php?showtopic=15814
I finally raised my bumper. What a ***** it was by myself. Looks 100x better though.
:big_banana_Dance:
I'm done with pictures for awhile :jester:
I was still lazy. I came up with the great idea of using washers to raise the bumper instead of cutting a steel spacer. I got it all back together and the one side was too low so I just had to undo one bolt and stick a couple more shims in :head: I am reconsidering buying an HD hood again.
well I'll just cheat
BEFORE
AFTER
except my truck is dirty right now. (look at the wheels)
http://www.gmfullsize.com/forum/showthread.php?t=130344
JKmotorsports
Austin, TX
^^^That's exactly what I did. It wasn't perfect when I bought it so I used body washers to get my bumper lined up evenly.
BOSS
The People's A D M I N
Dallas
So what exactly are body washers? Is that like Eddy Murphy's bathers? :)
No seriously what are they? :wtf2:
B
tybardy
tybardy
Gilbert Arizona
i just assumed regular washers, but since we are asking.... what are body washers?
brndns_hoe
Plano, TX
damn that looked like a lot of work to do...maybe not, but i just feel lazy today and seeing that just made the feeling worse
Jamison
Chevy Fan
Knoxville, TN
This is crazy, I was just looking at the pics of my truck that I just posted and was thinking how the hell to fix the gap too. I'm going to attempt this on tues i think.
Fyrcaptain
Richmond, VA
It looks right in your sig......you tap something or have it off for any reason since that pic.......
tybardy
tybardy
Gilbert Arizona
yea my friend backed his trailor hitch into it, check out the little black spot right in the center of the bumper
BOSS
Dallas
Pics and let us know how it goes :waytogo:
BOSS
thejstar
Hutto, Texas
hey ty, since we have the same wheels, what size rubber you running on them? i am thinking about going to go to a 305/50 next tire change...
Stik
charleston, S.C.
great something else to add to very long list of shit i need to do..lol
very nice writeup tast101....
JeffK
