How to fix Hot Air when A/C is on. Install new air mix/blend door actuator
viperbluelx
My '04 Tahoe with climate control needed a blend door actuator. Symptoms were: Intermittent hot air with A/C on - usually it would stay hot. At first, as others have experienced, turning off ignition and restarting vehicle would correct. Even that trick eventually just stopped working however. When the hot aired flowed the blower would speed up too - when in the automatic mode.
GM part number was 89018365. I paid about $150 for it - I'm sure you can get it cheaper in Dorman or at thru an AC/Delco Distributor.
Which specific actuator did you change? The easy one near the center console.
dubyatf
Actually, I had somebody install it. Judging from what I was charged and how long it took to R&R - I'd say it was the easy one to change.
[Edit: I'll add to my symptoms in case it might help others troubleshoot... Both the left and right front vents had the same issues though I can't remember if the defrost worked as it should. The rear A/C worked fine however.]
Darthkim
Dudes, for the life of me i don't understand where the blend door actuator IS on the 2004 GMC Yukon.
My symptom is that the driver side is hot, while the rest of the AC is fine.
I understand that I should change the left side actuator, but earlier today I replaced what I now know as the mode actuator.
Can someone tell me where this part is (in layman terms? )
o'doyle
Shawnee, OK
Having the same issues with the wife's 05 Tahoe.. Drivers side will get hot while everything else is nice and cool. Turning the ignition off and back on is working for now but from the sounds of it that isn't a permanent fix ..
Sounds like the actuator near the center is to blame
ktmhans
Connecticut
So reading threw this thread i think i have a good handle on whats wrong with mine. Also posters should be read the whole thread and get there answers. Theyve been answered. But what im wondering , is there a test method to see if these little buggers are working. Can you just have the truck running, crank the knob and watch it move? All the different ones.
I not only have the heat problem my blower sometimes doesnt blow hard, like 50% i would say. Then you play around with climate control and boom it rams up and blows hard. I saw maybe a blower risistor? Any help on that one.
balexander26
I don't think this is a good idea. I have done this exact thing to test if one of mine were working. It appears that the motor actually has a sensor that stops the motor when it feels resistance...and if it's not connected to the vehicle it will not feel resistance therefore it will turn too far.
So now I have this actuator off the vehicle and cannot reinstall it because the motor has turned the shaft too far...anyone know how to recalibrate it so it can fit back onto the vehicle?
pjtoy2
Banned
Chicago
OK i did read through this whole thread and I'm not sure if I missed it but I cant find the location of the rear actuator...
balexander26
This might help you: http://www.tahoeyukonforum.com/forum/showthread.php?t=12635
---------- Post added at 06:12 PM ---------- Previous post was at 05:38 PM ----------
Just in case anyone wants to know the answer to this. Took out the actuator P/N 52402588 and opened it up. All the gears were in good shape but there are 2 phosphor bronze semicircular wipers under the final gear which I believe send the feedback signal. Cleaned both, bent the wipers a little more and lightly relubed the gears. Set the actuator in mid position along with the door. (just barely reach it as it protrudes almost to the right side of the floor hump) re installed it and it has been functioning correctly.
Still having cold air coming out my passenger side when the heat is on so it's looking like I'm going to have to remove the dash to replace that top actuator.
Anyone know if it can be reached through the glove box?
Fordbeater
In addition to faulty actuator motors, the blend door itself can also be broken. This happened on my Tahoe. Typically it is a very labor intensive and costly fix to replace a broken blend door, as the dash must be removed and the plenum assembly replaced. There is a DIY kit from heatertreater.net that provides steel hardware as well as instructions on how to perform the repair by removing the glove box rather than the entire dash.
This is also an alternative to replacing the 'difficult to access' top actuator motor underneath the dash. The kit contains a single blend door which converts the dual control to single control, and is operated off of the bottom actuator motor, which can be accessed by removing the glovebox. If you are having issues with your blend door, or the 'top blend door actuator motor behind the dash' it is worth looking into.
DoABurnout
Access???
So I've narrowed it down to both the L&R and recirc actuators (See attached #1 and #2) HVAC.jpg My question:are these actually doable without removing the whole HVAC Module? I started to dig into it and it doesn't look like much fun....
oakrdrs187
Coachella,CA
KUDOS to the O.P!!
Also goes to show a simple search goes a long way!!
Since I don't drive my 04 as much anymore I went to my folks house where it's parked to start it but the battery was dead, jumped it and got it going. Noticed the passenger side blowing very hot. Quickly got to searching and found this, I didn't replace anything but tried the calibration in the first post and it worked! You could hear the door under the dash upon opening the ignition and holding it for a minute. Maybe mine is going but atleast I got it to work while I save up for an oem piece.
Sent from my Rooted Droid X using hacked Tapatalk 2
mattbta
Frisco, TX
Agreed.
I registered just to say thanks for the write up! Good job. Replaced mine last week after finally getting that dern bolt out on the hush panel. Got the blister on my finger to prove it!
Took me a few tries calibrating but it has been spot on so far once done correctly.
Many thanks! Cheers!
tmtb2013
Louisiana
My problem is that my driver side heat only blows cold. The heat works everywhere else, and the air blows cold out of the drivers side. I have had this problem for about a year, I researched it before and I knew it was an actuator but I'm still not sure which one it is. Any help with this would be great, also if it matters it is on an 04 Burban.
fire730
Louisiana
Agreed.
That one bolt is the most horrible part of this job! That one bolt takes longer than the rest of the job (including picking up the part from the store :Boo:)
jfjcld04z71
Ft Lee, VA
Does anyone have a write-up, or know where one is, on accessing the passenger's-side blend door actuator (the one behind the radio)? I have an '04 Tahoe with electronic dual climate zone controls. I have already pulled the radio and the climate control HU, but can't access anything back there due to the dash structure being in the way. Tried pulling my glove box out, but couldn't get the far left side off. Do I have to take the center console out just to get the glove box all the way out? Thanks in advance for your help.
---------- Post added at 12:08 PM ---------- Previous post was at 11:34 AM ----------
Never mind; I found it here:
http://www.sparkys-answers.com/2011/03/2004-chevrolet-silverado-dash-cover.html
...and here (continuation of first link; there is a link inside the above link to get to the below link, but just wanted to put it here just in case):
http://www.sparkys-answers.com/2011/03/2004-chevrolet-silverado-changing.html
scottvan
I have a 2004 LT with digital A/C controls.
Well, I changed my battery the other day, started it up, and I got hot air blowing through the windshield vents. The A/C was set to 60F. The rear A/C seemed to be working fine. I couldn't turn down the heat on the front unless I turned it all off. I also couldn't change the output vents, although the digital display said 60F and front panel. So I disconnected the battery for a minute, reconnected it, started it up and left the A/C off for a few minutes. Turning it back on, I was able to direct the air to whichever vents I want, but it was still blowing hot air. Rear A/C working fine.
It seems to be working normally now. I had read somewhere on the internets that pressing the #1 seat position setting resets the A/C computer, and I guess that is what has fixed it. I say fixed it, in that it is now blowing cold air, and since it's 90F here, I'm not going to experiment with the A/C controls any further.
Has anyone here ever had this problem when disconnecting the battery?
mykon04
Porter, Texas
Blend door actuator
I just wanted to say thanks to everybody who contributed to this thread. I replaced my blend door actuator and ran through the progam steps and it came out perfect. I did alot of research and even found a write up on it on another website.
My first issue was the passenger side would get hot while the driver side would stay cold no issue unless the wife was riding with me. Just recently the driver side started turning hot while the passenger side would stay cold. I pulled off the hush panel and noticed when the knob was turned all the way to hot the actuator would not function. I ordered the part from rock auto three days later took about thirty minutes tops and had it all fixed and put back together.
Thanks TYF, Justin
TIMHUTCHISON
I screwed up and plugged up the actuator and activated it so that it would be in the same position that the old one was in......now I can only get cold air to blow out no matter where I turn the temp knob. I have dual air....so I changed the one on the driver's side. Any ideas???
Phlipnstik
