Fog retro question
DenaliAK
DenaliAK
Colder than you
Alaska
It's those crazy kids from 90210....
Yep, I used to watch that show. Still not on the truck. Temps are up a tad but not hugely. I may get brave here in a bit and go at least start taking out the existing setup.
DenaliAK
DenaliAK
Colder than you
Alaska
Got them installed. I'm freezing my ass off at the moment, but will take pics and adjust later tonight (I'm four hours behind you East Coast guys....). We'll see how they look, but initial impression is that I'm not blown away by the output. It may take some getting used to having a controlled beam in the fogs vs. my old, blast light everywhere reflector set up.
DenaliAK
DenaliAK
Colder than you
Alaska
Meh.
Considering these are 55w HIDs, I expected more light.
Alright spectators, here you go, a couple of output shots. I'll get some externals of what the lights actually look like in the day time tomorrow:
DenaliAK
DenaliAK
Colder than you
Alaska
I think it's interesting that the flicker at the cutoff is green...it's kind of cool.
Couple of installed shots:
chauncey0337
MLT, WA
Yeah the yellow does look kind of green at some angles, looks cool. Nice work Scott
rippinitup
NY.
dam they look pretty nice man. looks like you can drive easily with just the fogs on. doesnt look like it has alot of width output from close range. do they?
ezdaar
Chat Troll
Redneck central, Aka Houston
The outter lens is diffusing the light, quite abit.
When it warms up, might want to try and chrome line those outter housings.
They also 55$ ebays, cant expect TSX or S2k quality from them.
I know your not going to want to do it, but toss a set of 4500's in them and watch how much brighter they are.
Yellow is a very deceiving color for eyeballing lumen output.
Tho they are very bright for what they are bud, dont be dissapointed.
I often finding myself wanting more lumen output from my setup, its just what happens once you go HID and projectors.
you get use to it then question your setup.
It looks really good bud.
DenaliAK
DenaliAK
Colder than you
Alaska
No, there really isn't that much width to them, which isn't all that surprising given the small size and very compact bowl shape. I would have liked more width, but I'm not shocked it's lacking, either.
Thanks. I was actually thinking about trying some 4300k bulbs just for comparison. I really wanted to see the 3000k results. I bet you're right, though: I think the light would look much more impressive. All things considered, price of the projectors, etc. it came out looking really good and matches my headlights almost perfectly, and the light isn't horrible. It was worth the effort, but I will always wonder if I should have stuck with the Fusions or gotten Blazers instead. I was having so many issues with the Fusions, though. If I do anything with them in the future I am not going to take them apart at all....I just screwed them up, ultimately.
---------- Post added at 08:45 PM ---------- Previous post was at 08:28 PM ----------
That's a little disconcerting; I blurred my license plate in all those pics on photobucket, yet it's showing up for all to see on here. That's messed up.
DenaliAK
DenaliAK
Colder than you
Alaska
No problem..would you say these projectors have a way better output over stock?
Depends on how you define "better."
They are way more controlled, have a definite cutoff, and make running HIDs way easier on on-coming traffic's eyes. My old ones were bright, but it was just light sprayed everywhere. These are much better at having a controllable beam that you can adjust to be completely out of other's eyes.
The only way I could fairly compare the two for actual output would be to put some 4500k bulbs in them and see how they do. I imagine it would make it look much brighter than the 3000k lights.
As they are now, I can drive down the street with just the fogs, but they only throw so far, especially being that close to the ground.
---------- Post added at 01:24 AM ---------- Previous post was at 01:21 AM ----------
buy another set and do this with out the outer housings.
Completely reversible mod.
think you will find, they will look identical visually from the front and without the extra glass you will get this much sharper and wider
I'm contemplating getting another set and just mounting them under the bumper in between the tow hooks. That'd give me a fair comparison. I'd run 4300k, too.
Rivieraracing
Looks like you did another killer job on the retro's, it's nice having the cutoff built into the fogs so like you said you can drive around with them on and not blind the others around you!!
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Damn I just was going to say it'd look boss if you put some in there.. Beat me to it!!
pnap88p
i need a purchase list with item numbers on what to buy todo this for my 2008 tahoe
DenaliAK
DenaliAK
Colder than you
Alaska
Not sure what fog light the '08 Tahoes use, but everything else is in the thread. The exact coupling you'd use might differ from a Denali because I think the fogs are different. Pretty much everything but the projector itself might be different for your truck, I'm just not sure.
Here's where I got the projectors:
P1 Universal Projector: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&vxp=mtr&item=370559716028
DenaliAK
DenaliAK
Colder than you
Alaska
As requested, an update on things:
While I'm happy with the look, I'm not pleased with the overall output. There just isn't much added light in the whole equation. That said, they are 3000k. Very yellow 3000k, too, I might add. If you want a deep yellow light, get the Morimoto's. They aren't messing around. I have a feeling the coating to get that color is cutting the output lumens significantly. When I get some more cash I'll order some 4300k bulbs to match my headlights and try that combo out. I think that's going to give me much more light.
I was in the yard when my wife came home the other night, and I have to say it looks pretty darn good coming at you. The cutoff does a good job, too. I didn't get any light directly in the eyes, and I even squatted down a bit to be more at another driver's level.
All in all, I settled, and it's going to bug me. Next time I'll do it proper. There's enough room on the Denali to fit almost any projector in there, so I may go more all out. It'd be sick to get the throw of an S2000 projector in the fogs, and I may try. Right now, I'm working on a more basic project: Scraping together some Hella 500's to put on a homemade little light bar. For now, I'm just going to stick with 100w halogen bulbs and see how they work, but I may do an HID conversion on those, too, eventually....we'll see. I'm trying to design it so the light bar is kind of universal and attaches to the license plate screw holes so I can transfer it from one car to another with minimal effort. I'll wire both cars up and come up with some quick connections in the grill.
D Rollins
