Your Vehicles as they sit now....
thumper_ehhhhh
Canada ehhhhh
before stolen
recovered and written off this is how she sits in the wreckers drivers window wide open so sad
Alex33
It is lower than an average drop for sure. I have done a lot to get it there.
What do you have installed suspension wise?
Trevor, that sucks bro. They didn't take much it looks like, just enough to ruin a good truck.
LI99HOE
Top Notch Tech.
N.Y.
Mine chillin' in my driveway....
I got an RBP black locking gas door on it now.
MeanGreen03
TX
DJM arms and spindles up front, DJM TB coils out back with cut coils. I also body dropped it so that's another ~3/4". For some reason I can't get the passenger front to come down any more. It is around 3/4" higher than the driver side and I have the torsion bar bolt all of the way out. I should probably get a drop key for that side but it may lower it too much. The drivers side torsion bar bolt is pretty much all of the way in. It sits ~32.25" from ground to fender lip with a 305/35/24 tire the last time I measured when I finished it all up.
Alex33
Def a lot of parts, but the truck looks great!!
Alex33
Thanks!! I appreciate it... Yours looks great as well! How are you liking the new drop?
It rides very well. I put about 250mi on it this weekend and I'm very pleased. Half of the drive I was pulling a trailer loaded with a CBR954RR and it didn't bang around at all. I think it rides better at 30.5/32 than it did before at 32.5/34 :Handshake:
capt68
New paint
I just got the Hoe back from the beauty shop. From black to red. Next up....interior and a little closer to the ground.
Rpprvnce
Memphis
What do you guys think?
LI99HOE
Top Notch Tech.
N.Y.
Awesome winch setup.... I'm diggin' the top carrier w/the lights too.
Did you have to drill through for the wiring?
---------- Post added at 05:06 PM ---------- Previous post was at 05:04 PM ----------
Looks good.... can't wait to see the finished results.
Rpprvnce
Memphis
Thanks guys!!
Man the wiring was the sweetest part of it all!!! I ran it up the back door underneath the back left vent cover and when i got to the roof i drilled a hole on the inside of the plastic cover that the factory luggage bars bolt to the top of the truck, then ran the wires down the inside track of the bars and then up and directly out to the lights! So the only place you can see the wires is directly behind the truck for like 6 inches and they have that black plastic wire wrap around them. ill take a pic and put it on later
brice715
