I Haz Hoist Conundrum
soulsea
Bar
Hi ... :)
So I'm trying to figure something out and I need help ...
I am about to order a spare wheel kit for my HyHoe. For those that don't know the Tahoe Hybrid comes without a spare for weight/fuel savings, it comes with an emergency tire inflation thingie.
The spare wheel kit pn is: 22754574
And comes with all the stuff I need including the 17" wheel, hoist, etc, but for the tire itself which I will pick up locally on the cheap.
Now this is where I'm getting myself confused ... there's another hoist out there (pn 19158309) which states the following:
A Spare Wheel Hoist Package is required when installing 22-inch wheels on a full-size SUV that has not come from the factory with this size wheel. The hoist holds up the spare tire beneath the SUV and is capable of handling the additional loads put on your vehicle when 22-inch wheels are installed. For Use on Hybrid Models. Contains Full-Size 17' Spare Wheel, Jack Assembly, Mounting Brackets and Associated Hardware. 17' Spare Tire (89049423) and Rear Fascia Access Hole Cover Sold Separately. Spare Wheel Hoist Package - For Use With Accessory 22' Wheel Only FOR 22' WHEEL ONLY
http://www.shopchevyparts.com/wheels/spare-wheel-hoist-package/19158309-p-134.html
This makes no sense to me, what does the size of the wheels on the truck have to do with the spare wheel hoist? :think:
Doesn't the hoist just hold up the spare?
And if so, since the spare is the standard 17" why would it require a different hoist just cause I'm rolling on 22s?
I asked my parts guy and he couldn't figure it out either.
I even asked him if escalades had full size spares figuring that the hoist was made for those and he said nope, eskys come with the same 17" spare.
The only thing I could think of is that this hoist is in case someone wanted to shlep a full size spare ... but is that even possible with these trucks? Doesn't seem that it would fit under there. Plus that's not what they are saying in the above description ... as I read it they mean if I have 22s on the truck itself.
I'm at a loss on this one so any help figuring it out is welcome and appreciated.
smurphy80
I may be totally off, but maybe they are referring to storage of the damaged or flat tire (22" wheel) beneath the truck until getting to a shop?
soulsea
soulsea
Bar
Mmm, that's a very good hypothesis.
Never thought anyone would put it anywhere other than in the trunk.
The only thing I wonder about though, is how could a 22" wheel with a 285/45 tire fit in a carrier that normally fits a 17" wheel with a 265/70/17 tire. :think:
ghoster
Baltimore
They have to be very close to the same overall diameter don't they?
soulsea
soulsea
Bar
Well, it's closer than I would have thought:
picture.php
I wonder if this means one could have a full size spare all the time then?
stevek
Dallas, TX
I don't even know if they make bi-directional tires in a full size like that...
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
throw it on the top and strap it like a safari rig. Problem solved
KMeloney
I'll be following this thread, as I want to get a large brake kit, and will be needing to use something larger than a 17" wheel as a spare...
soulsea
soulsea
Bar
I ordered the kit and the stronger hoist and it's getting installed next week.
When it's being installed I'll have a look to see how much room there is in the wheel cradle for a bigger/wheel tire ... but my guess is if it can fit the oem 22s you can put another wheel in there as long as the overall size isn't too different. You'll just have to swap to the stronger hoist for it.
soulsea
soulsea
Bar
Find a bidirectional tire...
Bi-directional tire for my spare?
I was going to buy the GM spec GOODYEAR WRANGLER ST 265/70/17 spare tire ... why would I need anything more complicated for short distances? :think:
stevek
Dallas, TX
Thought you were putting a full-size spare on there?
dizhai
