CR@P! I just realized last night that my NAV doesn't work now. I must have screwed something up when I did the LP. What might I have done?
Can you be more specific? Your NAV doesn't work at all or only after you activate the DVD in Motion feature. If the latter, that is "normal".
http://www.tahoeyukonforum.com/forum/showpost.php?p=320115&postcount=6
Bought it, thanks. Much appreciated.
This will make things a tad easier when we stay at hotels too with the kids.
Well I'm going to have to check on the way home today. I went to use NAV for the first time since installing LP, I was driving so I figured I better turn on the NAV in motion feature, I did then I set my directions to home while still driving. I clicked go and she said "proceed to highlighted route" which was wierd because I was on a main road, but then after a minute I realized it had no idea where I was and the screen would only change compass direction and not anything else. So it just sat there on some street unknown to me and never moved. I left it on for a good 5 minutes so I'm not sure if the 60 second feature should have kicked in.
Does this sound right or no? I'll try using it without changing the NAV in motion feature in the LP.
I know this off the subject but I have a 07 Yukon denali xl came with xm Bose rear video ent. I bought a navi unit #15882766 with antenna and back up cam and a wire harness. It came out of an 07 burban it also has the same options I have. I hook the antenna up but not the camera yet or the brown connector. ( I figured since my truck already had a brown connector I didn't need to connect it) so I hook the navi up and got a theft lock. I took it to a place that could take the old vin out and it worked everything works but no sound. The guy I got it from said that everything worked. Do it have something to do with that brown he gave me? Green wire yellow RCA red and black wire that has 07 08 Yukon Denali only. Can anyone help me?
Brandon
I just installed mine and I have the same problems. Do you know which is the GPS antenna cable? Is it the same as the XM antenna?
I continue to find the electronics in my truck glitchy. can't figure out if it is a GM issue, a GMX550 issue, or an incompatibility issue between the GMX and my BlueFusion unit.
Anyhow, every now and then the radio won't turn on. hitting the cd eject button always solves that.
sometimes my nav will be off because i activate nav in motion which disables the gps. after turning off nav in motion the nav eventually figures out where I am.
every now and then i can't get the GMX menu in the instrument cluster to turn off. the menu continues to be displayed even if i'm trying to push the dash buttons to view the odometer and stuff. doesn't revert to normal until i turn off the truck.
other than that i feel the pluses outweigh the minuses...but not by as much as i had hoped.![]()
...The lockpick should always be off all settings when you don't need it and the truck should be back to normal. That is what I do and now everything works great.
I guess I'm the only one that has the lockpick and has no problems with it... My only gripe is how thick the iPod dock connector cable is. I have it in both vehicles and have it ran to the center console. It's hard to close the center console lid when using the dock connector cable since the cable is absurdly thick.
