Disable front autoride only?
bodymccannx
Hey guys, have recently installed the Belltech 2/3-4 kit on my 07 Burban. I am now thinking I want to go lower in the front and it has been suggested not to use the Belltech 1-2" front springs (not sure why). I am considering the Belltech adjustable front struts; if I go this route, can I have the computer reflashed to eliminate the front Autoride code only (That is, retain the Autoride set-up in the rear), so that I don't have any DIC messages?
NORCAL SS
SUV SUSPENSION GURU
i just dont like going lower on the autoride struts but ive done it and it has worked out. at the 1 inch level just use the spacers. also look into the belltech camber bushings. anything else just hollar.
B
bodymccannx
So, Tony, you're saying to go ahead and use the front 1-2" springs, use the 1 inch spacer, and keep the Autoride struts for my application? If I did instead, go the route you suggest in other posts, and get the adjustable struts, can the computer be reflashed to remove front Autoride codes and the rear Autoride system still work?
I want to do this the way that will give the most responsive and reliable ride.
Thanks, Mark
NORCAL SS
SUV SUSPENSION GURU
the newer air system is a pain 00-06 was easier.
when i do them i do it at the 1 inch level at most i really dont like doing the 2 inch level.
CKendrick
