Dashboard Install
bablurp
Delano, CA
Just got a pricing on a dashboard from LKQ and I was satisfied. Seeing as I have never installed a dashboard I decided to go the professional route and get quotes..... Bad bad. It ranges from 450 to 600. Can someone direct me in the right direction so I can install this. I can probably install this at work over a weekend given the right instructions and provided I have the right tools.
Thanks
P.S. It's a 1996 2dr Tahoe
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Service and Repair INSTRUMENT PANEL ASSEMBLY REPLACEMENT
Remove or Disconnect
  1. Negative battery cable(s).
  2. Disable SIR system.
  3. Three relay center bolts from inside wheel opening and set aside.
  4. Bulkhead connector.
    • Two screws retaining Convenience Center to cowl.
    • Cruise control harness (if equipped).
    • Forward lamp harness.
    • Rear lamp harness.
    • SIR system harness.
    • Relay center.
  1. Antenna lead-in.
  2. Steering shaft bolt.
120471988
  1. Left and right hinge pillar trim panels.
  2. Brake release handle from the cable.
    • Clip releases handle from cable.
120471990
  1. Four lower bolster screws.
    1. Unsnap bolster.
    2. Twist brake release cable to disengage.
    3. Lap cooler hose.
  1. Reaction plate assembly.
  2. Tie bar.
  3. 8-way column connector.
  4. 48-way connector retainer to access two lower column nuts.
  5. Shift cable (automatic transmission).
  6. Steering column from the vehicle.
  7. Shift levers.
    1. Transfer case knob by pulling straight up.
    • Four wheel drive models must be in 4-LO range.
    1. Manual transmission (if equipped).
120471992
  1. Left and right lower I/P pivot bolts.
120472377
  1. Center support screw.
  2. Three upper I/P support screws.
  3. I/P from the cowl.
  4. Park brake release cable.
  5. Electrical connectors (as necessary).
    • DERM
    • HVAC
    • 22-way engine harness
    • Stoplamp switch
    • VSS calibrator module
    • Clutch or Brake release switches
    • Electronic accelerator (Diesel)
    • HVAC control cables (if equipped).
  1. I/P from the vehicle.
At this point, I/P removal is complete. Continue with the next step if replacing or refinishing the I/P.
120472379
120472385
  1. Accessory lamp switch(es) as necessary.
  2. Headlamp switch.
120472018
  1. Instrument cluster trim.
  2. HVAC control assembly.
    1. Electrical connectors.
    2. Cables (if equipped).
  1. Instrument cluster screws.
  2. Instrument cluster.
120472020
  1. I/P auxiliary storage compartments (if equipped).
120472022
  1. Ashtray.
    • Electrical connectors.
120472377
  1. I/P cupholder.
    • Retainer inserts from underneath.
    • Twist to the left to release.
  1. Two air distributor duct screws.
  2. Antenna lead-in.
    • Squeeze clips from front of I/P to release duct.
  1. Air distributor duct from the I/P.
  2. Rosebud retainers on right side of I/P for harness.
  3. Instrument panel compartment lamp.
    • Slide to release.
120472026
  1. I/P storage compartment.
    • Squeeze compartment to release.
120472077
  1. I/P liner assembly.
  2. Low coolant module (diesel only).
  3. Harness from the I/P.
  4. DLC.
    • One screw and slide out.
  1. Rosebud retaining harness to accessory switches.
  2. Fuse panel and courtesy lamps switch.
  3. Unclip turn signal flasher.
  4. Ground screw.
  5. Harness from the I/P.
  6. Jumper harness to remote playback device (if equipped).
  7. Antenna lead-in.
  8. Courtesy lamp switches.
  9. Side defog outlet.
  10. Park brake cable clip.
Install or Connect
  1. Antenna lead-in.
  2. Jumper harness to remote playback device (if equipped).
  3. Harness to the I/P
  4. Right side harness rosebud retainer.
  5. Fuse panel and two screws.
  6. Courtesy lamp switch and electrical connector.
  7. I/P cluster connector.
    • Insert through I/P and pull back to seat.
  1. Clip harness to the I/P
  2. Accessory outlet wiring.
  3. Harness to accessory switches.
    • Feed through holes.
  1. Ashtray.
  2. Instrument cluster with four screws.
  3. HVAC control assembly.
    • Cables (if equipped).
  1. Radio electrical connectors and lead-in (if equipped).
    • Radio snap fits to the I/P
  2. I/P cupholder.
    • Twist retainer to the right.
  1. Air distribution duct.
    1. Two snap-fit clips.
    2. Two screws.
  1. DLC.
  2. I/P cluster trim.
  3. Side window defogger outlets.
  4. I/P to the vehicle.
    • Rest I/P on lower pivot studs.
  1. Convenience center to the cowl.
  2. Lap cooler duct.
  3. DERM to the center I/P support.
  4. Nut to steering column support.
  5. Park brake cable.
  6. I/P pivot nuts.
  7. Upper I/P support screws.
  8. Steering column to the vehicle with four nuts.
  9. 48-way connector and screw built onto steering column.
  10. Tie bar with four nuts.
  11. Shift cable (automatic transmission).
  12. Accelerator electrical connector (diesel).
  13. knee bolster close out panel with two screws.
  14. Reaction plate with tour screws.
  15. Shift knobs.
    • Manual transmission.
    • Transfer case.
  1. Lap cooler hose.
  2. Park brake cable.
  3. Knee bolster trim snaps into place.
    • Four screws from the bottom.
  1. Park brake handle clips into place.
  2. Antenna lead-in at the fender.
  3. Bulkhead connector.
    1. Two retainer screws.
    2. One center screw.
  1. Electrical connectors in the engine compartment.
    • Cruise control (if equipped).
    • Rear lamps harness.
    • Forward lamps harness.
    • SIR.
    • Relay center.
    1. Two pivot points.
    2. Compartment snaps into place.
  1. Steering shaft and bolt.
  2. Enable SIR system.
  3. Negative battery cable.
Devs93
    • Relay center.
  1. Antenna lead-in.
120471988
120471990
    1. Unsnap bolster.
    3. Lap cooler hose.
  2. Tie bar.
  7. Shift levers.
120471992
120472377
    • DERM
    • HVAC
    • Stoplamp switch
120472379
120472385
  2. Headlamp switch.
120472018
120472020
120472022
  1. Ashtray.
120472377
  1. I/P cupholder.
  2. Antenna lead-in.
    • Slide to release.
120472026
120472077
  4. DLC.
  4. Ground screw.
  7. Antenna lead-in.
Install or Connect
  1. Antenna lead-in.
  1. Ashtray.
  2. I/P cupholder.
    2. Two screws.
  1. DLC.
  2. Lap cooler duct.
  6. I/P pivot nuts.
  15. Shift knobs.
    • Transfer case.
  1. Lap cooler hose.
    • SIR.
    • Relay center.
Were did you get this info I need it for 88/94 dash
SunlitComet
OBS Jedi-Do Good
Get yourself a subscription to alldata for the specific year. if it was in the service manual it should be in alldata. Frankly I do not think dash board info is absolutely needed for every individual though. :IMO:
Heavychevyvito
