20x12s
MandezeeFMB
I just bought a 2001 Tahoe Z71 Stock. I have some new 20x12 XD diesel rims with 33s. I want to know if i can get away with using a leveling kit for now. If so which one should i get?
M
MandezeeFMB
Thank you for your reply. I figured i would have to do some trimming but just not sure how much. I tried searching for some pictures online just to see what it would look like but the closest i found was someone running 20x10 with 33s. What leveling kit would you suggest i try?
brucebruce45
Go to ford dealership and ask for ford torsion keys, hey are all the same, get longer shocks, 2" spacer for rear from eBay. To fit those x12s ur gonna need atleast a 3"'bl or a real lift or cut something serious
Jbird
i fit 33 discovery stt's with 20x12 rockstars with just cranking the stock keys. youll be fine with lift keys
Jbird
yea i had 20x12 with 33s no lift at all. no trimming. then i had 20x10s with 35" toyo m/ts with just lift keys just had to do alittle trimming. people over exaggerate the rubbing issue
Max
Mile High
Denver
Completely dependent upon the offset but I'm a bit dubious about you running 20x12s with no lift and 33s. Cranked keys, high offset, and 305/50s maybe but these trucks don't clear wide ass wheels too easily without some trimming (which isn't bad if you do it right).
Jbird
i had cranked stock keys for the 33s but that barely leveled it out if that.
my buddies yukon behind it sat just as high as mine with 33s stock. i really think some just sit higher then others
brucebruce45
Those arnt x12s. The tires not even stretched and ur wheels are tucked. Can't fit x12s an 33s without major hacking on just keys
---------- Post added at 12:38 PM ---------- Previous post was at 12:01 PM ----------
These are x12s on 33s with a 6". Look how the tires are stretched and how far they stick out. Look how much the bumper had to be cut even with a cranked 6". Plz do research before posting bc its obvious u have no clue what wheel setup u have
LOUDHOE
Seneca, South Carolina
I dont think he was saying he had X12s he was just showing stock keys and 33s
M
MandezeeFMB
Thanks for everyones help. I think im just going to buy the rough country kit and try it. If it doesnt work out ill just sell them and buy some 26s
---------- Post added at 02:04 PM ---------- Previous post was at 02:01 PM ----------
XD Diesel's Machined 20x12's wrapped in 33x12.50's
jd123
Andaluisa, AL
It's gonna rub. I have 20x10's on 35's with keys, 1.5" spacers, and a 3" body lift and had to do quite a bit of trimming.
WildBill
12 is too wide. 20x8 to 20x10 and it will work for you. take pictures of the cutting!
westcoast
Salinas,CA
nice wheels hmm Ill have to try to see if something like that fits on my tahoe.
edit: If you do decide to sell them let me know thanks.
M
MandezeeFMB
---------- Post added at 01:20 PM ---------- Previous post was at 01:09 PM ----------
[/COLOR]
[/IMG] I Barely had to trim the front valance. Ill post more pics soon!
Buford bubba
