Thinking bout these Projectors
soulsea
Bar
Thanks bud, I appreciate the heads up ...
I got some contemplating to do about how and if to go forward.
THE YETI
Director of Operations
South FL
$150 is gonna make or break this project? Nooooo!!!!!! Do it! I've been looking forward to this!
:chicken:
soulsea
Bar
Sumo, I don't know if you're at this point yet with the install ... but have you found or foresee any issues fitting the two extra ballasts for the high beams?
It looks pretty tight in there. (gigitty)
sumo
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
there shouldnt be a problem. When i do go install i plan on removing the front bumper if it not to much to do. Last time i just removed the headlights and thought there was enough room to tuck the ballast somewhere and run the cables up.
InTruckDesign
SW CT,
There should be plenty of room for the ballasts, you could even mount them in the engine compartment the wires should be long enough.
To remove the grill/bumper is pretty easy, 10mm bolts across the top by the radiator, then 2 small screws and 2 push pins along the front of the wheelwell, and 2 10mm bolts underneath basically one behind each foglight or thereabouts...and disconnect the foglight wiring then just be careful and pull the whole she-bang off...I've had mine off so many times that I can do it in about 5 min. now.
sumo
sumo
rhode island
A little more before i get everthing Repainted and cleared. Didnt want to get Hassled for not having a side marker light. Since i was blacking out the reflectors, i need to have a marker Light. I drilled 3 7/64 holes along the area where the Marker light goes. NIow i dont feel as bad when i Totally black out the reflector. Now to find some yellow 194 led bulbs
picture.php
picture.php
picture.php
soulsea
Bar
Good idea there sumo, and well implemented.
It looks like you're almost there ... did you get the second set of shrouds yet?
I'm waiting for an extra set of housings from A1 Auto, then ship 'em off to the shop. It's going to take him about a week to do it, but then I'm out of town the week after that, so it looks like the install will be around two and half weeks from now.
I went with Gattling 2.0 as shrouds, if they don't fit properly he'll use his custom ones. It's a quad bi-xenon setup, with minis for highs and regular ballasts for lows if they fit, otherwise minis for lows as well. He's also putting leds for drls. He's also going to rewire and install my IPCW ruby red tails for free with leds as backup lamps.
That's the updated plan ... we shall see how it all pans out. :)
felixgun
Lafayette, LA
:popcorn:
sumo
sumo
rhode island
Yea I got the shrouds. Waiting on paint to dry.I was also taking to matt to discuss the option of making a dual head light and quad headlight using a switch.
soulsea
Bar
Interesting idea ... but what would be the advantage if I may ask? :think:
soulsea
Bar
Quick q ...
I've been talking to my install guy about the led drl and whether they need load resistors. His take is that as the leds draw less power than regular bulbs, they often mimic a blown bulb situation to on board computers and sometimes throw up a dash warning as a result. Does anyone know if this an issue on 07+ Hoes ... do we have a 'light bulb out' warning?
Other than that is there any reason to have load resistors?
Thanks
sumo
sumo
rhode island
no bulb out indicator. Drl dont need a resistor. I just used a 3157 Dual circuit Bulb for the Drl, and as far as the Turn signal, They do need a Resistor. 6ohm to be exact. If you dont have a resistor on the Turn, the system will think there is a bulb out and Flash fast
soulsea
Bar
ah, thanks bud.
I actually wasn't going to use leds for turn signals, just the stock orange bulbs. I assume no mod is required there? :think:
felixgun
Lafayette, LA
Quick q ...
Thanks
Yea you don't need resistors on the DRL's but you -do- need LED protectors on the DRL's though. One per LED DRL:
http://autolumination.com/equalizers.htm
Modded told me about them he said he blew a few pairs of them without putting the led protectors in.
soulsea
Bar
Ah, thanks Felix ... I passed it along to my guy.
At a couple of bucks each it's worth the peace of mind. :waytogo:
HeavyHoe03
