right rear sitting 1/2" lower than the rest
swtz71
Mass
I installed 3" springs and nitro drop shocks the other day, I lowered the stock keys about an inch even on both sides.
Today I noticed the right rear looked a bit lower than the other side.
So I measured all 4 corners and the right rear is sitting just over 1/2"...
What could I have done wrong or can I adjust with the front?
Any help would be awesome..
It's only noticeable if you look close...
Thanks
BlueTahoe2001
Charlotte, NC
Check your shocks and see if you have a bad one. If not, raise the right side a little and see what it does.
MASS-HOE'Z71
Mass
Dont think it would have anything to do with the woth the keys needing adjustment, especially if they the fronts are basically even. Theres a chance the shock could be the culprit if you pumped one of them to pressurize it and not the other or it could just be that they are new springs and need some breaking in.
If its that noticeable, and if your like me, your going to obsess over it until its fixed, maybe try pulling the spring isolator on the opposite side to see if that evens it out, that gives you like another 1/4"- 1/3". Shouldnt be anything wrong with that, nothing that i can think of atleast, and best of all its cheap.
The truck's looking real nice in your sig pic
swtz71
swtz71
Mass
I got the shocks used but they were only in the other truck a very short time. I can pull out the right side and see if it extends all the way out.
Mass-Hoe, Thanks I love the look, and yes I most likely will search for the solution for the 1/2" mystery!!
pats hoe
absecon,new jersey
Man that looks way better lowered now,i know its not the springs cause mine sat even in the back but my fronts i had to adjust one torsion key 1/2 different side to side to even the front out.Like the other guy said pull an isolator out of you have too on the other side thats higher.Looks great
jutte73
Dayton, OH
try switching the shocks and see if the problem follows the shocks. if not switch the springs see if the problem follows the spring. that will at least narrow down your possibilities and you can elimanate those two items. also check and make sure your end links on your rear stabalizer bare arent broke... good luck!
swtz71
swtz71
Mass
Thanks I will try the ol'e switch-a-roo !!
swtz71
swtz71
Mass
Truck hasn't been been around long enough for me to do anything yet. But I will update as soon as I do something
Sweet_N_Low
It may just be the factory "GM lean" our trucks have always been accustom to having. There are ALOT of trucks with inconsistent heights even from the factory
2005yukonxl
most cars/trucks are that way if u look on the various forums. it aint just a GM thing. heck, toyota builds em with the rear end cocked to one side haha.
NoPh33rRaCiNg
Kent, WA
the drivers side is usually lower in the gm lean, since the battery and gas tank are on that side. i had to adjust my keys because of that.
swtz71
swtz71
Mass
Did you ever found out what was the problem?
Never did find out what was up with this, but it did level itself a bit so it's not as bad nor noticeable. So I just left it alone..
CKendrick
