where does this belong? (random 3 wires under steering wheel)
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
i looked at my uncles 93 pickup and it didnt have any wires like that coming out of that area. im gonna assume it was a drl they may have used that harness on another truck that had drl or something too, i dont know.. GM is weird sometimes
Monstar_est87
City of Angeles
is anything not working properly in ur gauges..? I followed those same wires (turnd out not 2 b drls) and they run up behind the gauges 2 where I cant see...
86mk7
lititz pa
since ive been in my dash the last couple days i looked also. ive got a 99 yukon and the harness plugs into somthing that sits ontop of the colum. my drl are plugged in and its a seperate harness. mine are even the same colors as your. i wish i was of more help but i cant even get my hands above the colum to check it out for you
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
every thing seems to work properly on my gauges only thing is my PRNL light sometimes doesnt light up and you got to wiggle the gear selecter for it to work and when going to reverse to get the reverse lights to light up going from park to reverse you have to shift to neutral then reverse. but i figure that as the neutral saftey switch, ill take it apart sometime and see where thats suppose to go
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
good luck bro...
could have used more luck ha. yeah found nothing even remotely close to where it would go. the wires only reach so far... on the plus side i did find out why my seat belt/key/light alarm always went off. there is a spring above my ignition cylinder that if i hold it down it doesn't make the noise anymore. so i taped the spring down haha
Monstar_est87
City of Angeles
Wat ever works... I tried posting pictures but they werent the best quality but I saw mine going up the left of the steering column and up bhind the gauges where I couldnt see j.s...
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
i tried and tried to find a home for it but it really didnt reach that far. i took the cluster out and everything looking for where they go
96ProCompTahoe
IN
if it was a "late" 95 you could have gotten a harness for the newer trucks for something not used on the 95 model year.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I thought of the a year carry over thing to but still no color match. You did say you could trace them to the harness connector right?
Here is an exploded view of a '95 tilt column.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
the pictures too small again
---------- Post added at 08:11 AM ---------- Previous post was at 08:02 AM ----------
According to that i have a 95 blazer 1/2 ton build 1-26-1995 and apperently there is only one other vehical that they made with the exact same rpo list
AtomicHoe094
Atomichoe094
cleveland, OH
Thats a pretty early date for your truck. They made the fullsize 2 door Blazers and then changed the name in 95 to Tahoes. 95 was also the first yr for 4door tahoes/yukons.
Maybe you have the early harness for the old square dash and they had something for that connector..
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
does your Lights come on when you open your door? In my 89 sierra i had a probelm with the drivers Door switch that went bad causing the lights to stay on. I unplugged it and remembered it was a 3 wire but not sure of colors.
ERIC95TAHOE
ERIC95TAHOE
Southern Wisconsin
that was another thought but the harness probably was completely different from 94 to 95 because of the air bag and the cluster, heat/ac controls along with the radio are all different. so maybe?
i thought that was a really early date too... and why do they call it a blazer on that web site? says tahoe on the truck and its the tahoe interior...
but everything works. and as far as the doors good the light comes on and works fine, theres no way it could reach there anyways the wires only about like 4 inches long or less so it doesnt go very far
im beginning to think i should have never looked under there and never knew about it :emotions122:
AdrienR
