new guy...new questions. 3/5 drop
motocrossbrian
whats up?
im new to the forums and have a quick question. im looking to lower my 2000 tahoe limited a few inches and was looking at the DJM 3/5 drop kit for it but i heard it rides super rough and bottoms out a lot. any solutions to this problem?
thanks
Modded
That Guy
Almost all DJM stuff rides nasty, go McGaughys!
Max
Mile High
Denver
Well since you have the older body style truck I'd recommend you call your truck a 99 so you get the right parts. Does your truck look like this?
roadrageror
ROADRAGEROR
alberta,canada
i put a bell tech 4/4 on mine a few months ago..with smaller rubber also.it does ride rougher but the look is worth it to me! mine is a 4x4. got used to it after a few weeks.
---------- Post added at 02:22 PM ---------- Previous post was at 02:20 PM ----------
Max
Mile High
Denver
Pretty sure his is 2wd so it has coils up front. You'll want a belltech kit, here are some parts #s
2" pro front springs - 23452
2" spindles - 2500
Rear Shackle and Spring Hanger - 6636
This will net you a 4/4 drop, or you can go with a 1" drop spring up front. Rear is a ***** to get lower than 5" or so without cutting, they look pretty good dropped tho I think this is a 3/3 drop iirc
Modded
That Guy
You can run anything from Toxic, Belltech, McGaughys, DJM, Doestch drop shocks and on!
I don't know much abot Belltech shocks but I heard they're too soft, Max can confirm
Max
Mile High
Denver
Toxics are fine. If you buy coils get some belltech pros, they'll ride way nicer. It all depends on how you drop it and with which components.
Max
Mile High
Denver
Dude your truck is NOT TORSION BAR! Consider it a 99 otherwise you'll get incorrect parts. Totally different suspensions between the 95-00 OBS and the 00-06 NBS.
M
motocrossbrian
oh shit...any company make a 3/5 for that then? or whats the lowest drop i can get on this without going bags
---------- Post added at 09:05 PM ---------- Previous post was at 09:00 PM ----------
this is the only other kit close to 3/5 drop. its a 2/4...
http://www.stylintrucks.com/part.aspx?category|category_root|-30=Suspension&category|cat_-30|374=Lowering+Kits&partfamilyid=1708&partid=594757
think this kit would look sick? its only an inch diffrence from a 3/5.
but idk...what do you guys think?
Max
Mile High
Denver
I think you can go 5 or 6", I'd start with some 2" spindles and the 4" rear spring hanger/shackle kit. You can always hook some 1" or 2" front springs later but I think you'll be chill with just a 2/4 on that truck...body kit makes em look low as hell.
M
motocrossbrian
okay sweet. as you can tell im a noob with lowering cars and stuff. im used to lifting big trucks and motocross shit. but im slowly learning!
what do you mean hook 1 0r 2 inch springs on after i install that 2/4 kit? sorry if i ask any stupid questions. just throw on shorter springs after the fact?
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
if after the spindles are installed you're not happy with it being low enough you can THEN swap out the stock springs for a 1 or 2" drop spring...
AdrienR
