Changing Rims on a Hybrid
THE YETI
Director of Operations
South FL
when we sell the Asanti's on the burban, we'll be doing 24x11 and 24x9 on the burban... might go another inch lower too. :secret:
My wife kicks ass!!
Wow! 24x11??? Will those tuck in your rear wheel wells??
THE YETI
South FL
im not bagged so we're not looking for it to "tuck" but rather just fit flush with the fenders. havent measured, but we are 24x10 now and an extra inch looks like it'll work. :)
Yeah that's what I meant. I was mainly curious if the wheel stuck out of the fender at all. That is a really wide rim! :D
soulsea
soulsea
Bar
Well folks, the saga that has been this thread seems to be nearing its merciful end, as apparently does my warranty compliance ... and I think we can all thank the good lord for at least the former. :)
Agreement has been reached on a set which I should get delivered by the end of this coming week. I'm actually away next weekend so I might not have time to install them before I leave. I will however do it upon my return. Pics of course shall be taken, posted, and all shall rejoice. :)
Seriously though, I really want to thank everyone who has helped me out, both on this thread and via pms. Your input has been appreciated beyond what I can express without having my sexuality questioned. So hopefully a heartfelt thank you will do.
What's next?
Thread outlining next project pending ... I'll give you a hint: Have you ever asked yourself if Tahoes will float?
soulsea
soulsea
Bar
Quick question for the mathemagicians ...
The HyHoe has, in order to save weight, an emergency tire repair kit instead of a spare tire.
Now I know one of my options is to remove the resonator which in a HyHoe sits where the spare tire is in a regular Tahoe, add the spare tire kit with the tire and hoist, get a regular Tahoe bumper and (much $ later) Bob's your uncle. I was going to remove the resonator at some point anyway and probably get a regular bumper so I can get the hitch cover which doesn't exist for the HyHoe bumper.
However my question based on the premise that I don't do these mods ...
Can I use one of my current wheel/tire as a spare tire if I am willing to shlep it around in the trunk? I have the space cause I've already removed the 3rd row seats ... but I was wondering, if should I get a flat can I use one of these rims I'm taking off for a short distance without messing up the truck?
The stock wheels I'm removing are: Wheel Size: 18" x 8" 31mm offset and the tire is: 265-65-18 BRIDGESTONE DUELER HT
The wheels/tires I just bought are these: http://www.tahoeyukonforum.com/forum/showthread.php?t=23886
I'm not sure how to calculate the total circumference of both wheels, in fact I don't even know to what degree it matters if the emergency spare is slightly smaller or bigger than the other 3 wheels.
I suppose I could buy the oem spare and tire and put that in my trunk in case I get a flat ... although I can't imagine that would be the same circumference as the wheels I just bought anyway so the question would remain the same.
What do you guys do for a spare?
I mean, no one is buying rims/tires in sets of 5 and carry one in case of a flat ... right? :think:
stevek
Dallas, TX
IMO just put the wheels on, don't bother with a spare. With the money you save from not paying for a 5th wheel, you can buy AAA. If there is an issue, put the OEM's on and take the HyHoe in
soulsea
soulsea
Bar
I haz the AAA Plus thing already. So just call them, have them do the repair kit on the side of the road, and change tire at the first opportunity?
Or just have them tow you to your house where your stockers are then drive it up to the tire shop. Either that or tow it straight to the tire shop depending on distance. I know that my AAA covers up to 100 miles.
soulsea
soulsea
Bar
Mmm, my biggest concern is when I'm on the road ... I drive between DC and NYC quite often so towing me home won't be an option in this sit.
Is there a reason not to use the repair kit? :think:
Fix a flat will put all kinds of junk into your tire and some shops won't even touch the repair if you've used a repair kit first. What kinda repair kit are we talking here?
Also, in case of blow out a repair kit won't help ya :D
soulsea
soulsea
Bar
"Spare Tire Information
There is no spare tire in the 2009 VUE Hybrid, AURA Hybrid, SKY, or OUTLOOK XE. These vehicles have a tire sealant and compressor kit that uses a liquid tire sealant to temporarily seal up to a one-quarter-inch puncture in the tread area of the tire. After using the tire inflator kit, it is recommended that you take the tire to an authorized dealer for inspection and repair as soon as possible, but at least within 100 miles of driving. The tire sealant cannot seal and inflate sidewall damage, punctures larger than one-quarter inch, or a tire that has unseated from the wheel. The sealant can only be used on one tire and for one time before its expiration date."
From: http://www.flowgmautocenter.com/NewBuickWarranty.aspx
Why do you think I friended you, for your good looks?
Blowout = Call 07B for lift ASAP. :hands:
:lol: Well, I am pretty darn attractive!
stevek
Dallas, TX
Blowout kit for 100 miles, AAA for 100 miles. Pray the kit works, or have the tow take you to a tire shop.
soulsea
soulsea
Bar
Cognitive Dissonance on the subject of Flat Tire = [sheen]Winning!!![/sheen]
Gotcha. Drive and pray it all sorts itself out when the day comes. :)
Would that be "biwinning"???? :D
THE YETI
South FL
how about throwing the spare in the back when you travel over 100miles?
soulsea
soulsea
Bar
See this, this is the kind of clear reasoning I needed from the others .. thanks ScSS. :)
You sir get a trophy:
picture.php
Buford bubba
