315/35/24 and lowered?
B.G.
Anyone have a 2/3-4 drop and have 315/35/24's. I finally picked up some wheels. Going to order tires soon and the belltech setup from Tony. But want to be sure 315s will fit without any rubbing. I know offset plays a role, but in general does anyone know. Thanks
MOBmentality
Has a $25,000 Punch
im not sure hopefully someone will chime in but for the record a 315/35 is a pretty big tire.. most lowered on 24s are 305/30s or the 295/35 is a lil narrower but also a lil more sidewall so they arent as square..
NORCAL SS
SUV SUSPENSION GURU
that tire is to wide. I need to know your offset and width of the wheels then i can give you the correct answer
Modded
That Guy
Save yourself the headache and get a 305/35/24 with a +35 offset or higher.
carcrz
Georgia
B.G. i got those 315/35/24's with a 2/3 belltech drop and yes is a big tire but my dont rub much at all just the front when you turn sharp and in the back i put 1/4 inch spacers and that fix it, but if you can get a smaller tire
B
B.G.
Thanks for the input.. The sole reason for wanting that wide is because for some reason they are less $$$ :( than the 305's
NORCAL SS
SUV SUSPENSION GURU
www.onlinetires.com thats where i get my customers tires from and then lots of times I just have discount tires beat it.
they hvae cheap tires there like 140 each for 305 35 24
ALL4WD
My 315/35/24 rubbed at stock height in couple of spots, so I'm guessing it would be even worse lowered.
B
B.G.
Good lookin out man... Gonna be hitting you up REAL soon for suspension. I dont like 4x4'n it...:mexsmoke:
T-Giv
Colorado Springs, CO
Yeah Norcal will set you up right. He knows his **** on dropping and the pricing is great. I can't wait to get mine dropped.
CKendrick
