Transmissions... Looking to replace.. Thoughts?
bkboatnsleds
McHenry, IL
Am I being dumb? Here are my thoughts.....
I have a 2003 Tahoe 4x4 with 140k miles on it. I hear 150k miles is the magic number on these things...
Little background, she is my daily driver - About 45k ago I put in the 6.0L LQ9 motor. - I do tow fairly frequently with it - I have a custom tune...
I know this stock tranny is not going to last forever and I was thinking I'd rather swap out the tranny now while is still working for a few reasons...
1- I'll have a good rebuild-able core
2- I can do it on MY time and not rush to get the car up n running again
3- piece of mind if i'm on a long trip... knowing I wont have to have it towed..
So anyhow the tranny has been acting fine mostly but I'd like to upgrade a little bit for the extra power of the 6.0L I put in.
I was thinking of upgrading to the 4L65E as seen here:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250508409561&ssPageName=STRK:MEWAX:IT
With this TC as a thought as well:
http://circledspecialties.com/p-50-gm-278mm-hp-4l60e-ls-torque-converter.aspx
What are your thoughts about my plan - different suggestions??
Thanks guys!!!
NorthOC Ca
i wish i could do a 6.0 swap, even better a 6.2 but that will come in time. ive heard the 4l80e (hd transmission) bolts right up but im not to knowledgable about tranny swaps, but might be something to look into
bkboatnsleds
bkboatnsleds
McHenry, IL
The 4l80e does not bolt up from what I read. It requires a different cross member mount and wire harness to make it work -
I don't think I want to screw w/ all of that.
JKmotorsports
Austin, TX
The trans wouldnt be a bad idea, but I'd do more research on a new tc. If you tow often, make sure the tc has tcc lock-up and will hold while you're towing, otherwise, there will be a lot of slipping and heat build up. Transmissions don't like heat at all.
And you are right about the 4l80 not being a direct swap.
bkboatnsleds
bkboatnsleds
McHenry, IL
have it built into at least a 65e, or get one already built..
Something like this.. ?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
---------- Post added at 12:41 PM ---------- Previous post was at 12:40 PM ----------
Thanks. Any suggestions on places for the TC?
MASS-HOE'Z71
Mass
ebay listing was removed
probably depends on what you are looking to spend. most trans shops can re-build a pretty strong transmission for under 1700 or so and the work should be warranted. if you were looking to buy a new one to swap, ive been looking at performabuilt.com for a bit now. they do performance transmissions as well as heavy duty towing package transmission, bit more money but from what i hear the warranties on them would be worth the extra spent if you plan on keeping the truck for awhile
http://performabuilt.com/heavy%20hauler%20700-60E.html
NORCAL SS
SUV SUSPENSION GURU
i would talk to rpm transmission or flt transmission. I have built 4l70es on both of my trailblazer ss's and both over 500 rwhp and no probs at all.
now my buddy has a silverado and has gone thru 2 performabuilt trans in less than 2 years and he never races the thing
Travieso
Boooooooost !
Los Skandeles, CA
subscribe good info here guys
as im adding more power to La Guera (tahoe)
i might as well start thinking in the future...
Jumpshot12
