want to lift 2000 yukon denali
philwil1001
whats the best way to lift 2000 denali. all kits i've seen say except denali. don't understand why can't find one for it. but would appreciate any advice on how i could raise it 2 to 4 inches without costing an arm and a leg.
DaRosa218
The Dude abides
Modesto, California
My buddy has a 2005 'Nali and went to 4wheel parts to see if he can have it lifted. They told him no dice because the 'Nali's have AWD and will cause vibrations in the driveshafts. Sounded weird to me so I called around and no one would lift it because of vibration issues found after lifting them.
You could try keys and spacers and see what happens. At least with the keys and spacers, they can simply be removed if they are causing issues.
Tahoewhat
Ballin' on a Budget
TX
to add...
Not sure what year, but here is some addition to what DaRosa said,
http://www.gm-trucks.com/forums/index.php?showtopic=84349
I know its not a NBS, but heres a NNBS Truck Denali.
http://i264.photobucket.com/albums/ii177/OutlawBiz/DriverSide-1.jpg
Supposeably this is a 4x4 Burban. Not sure if thats the same as a Denali awd though
http://socaltrucks.com/forsale/images/oscar_vascos1.jpg
Heres a kit, but just says keys and spacers for the coils..
http://www.readylift.com/c-191-gmc-...00-sst-lift-kit-2000-2006-2wd-4wd-25f10r.aspx
Dont know if any of this really helps you out. Didnt read the first link thread, but said deanli and expands on darosa's saying... Might help you out, dont know..
Just my .02 trying to help.. Im sure someone has done it.
(and is it a 2000, b/c this is the 07 on Section, skip down a section for NBS)
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Its really the autoride shocks that mess everything up too. I would send a PM to max, he just leveled a NNBS denali
PUGLIA
Oklahoma
Auto ride is just a leveling sensor electronically tied into the compressor that fills air shocks.The electronic part of it can be bypassed by a resistor placed on the wires running to each of the shocks, this fools the computer into thinking your system is still hooked up then you can then ditch the air-shocks and replace with regular ones. I converted my LT from autoride a while back.
Jakesmith
Alabama
hey guys im new here but i am really wanting some suggestions on how to go about lifting my hoe.
i have about 4 grand to work with my list of mods that i still want is ----2-4 in lift, rock star rims (what ever will fit). all terrain tires.i also want a brush guard ,tinted windows,and blacked out headlights and tail lights......so far i have installed subs new black emblems and weather tech floor matts.
Thanks, Jake
noleman724
2000 denali
most any kit for 2000 yukon will fit 2000 denali has no air ride or all time awd that started in 2001 the 00 is the same as 00 yukon just upgraded seats etc. i have lifted 2 and never had any problems
Merch619
