Newbie needs help. (HID related)
02HoeZ71
First and foremost, some sick rides on here.
Secondly, Just bought my DDM Tuning kit for my 02 Tahoe. Lows only for now and they don't light up, any suggestions? Help is appreciated.
02HoeZ71
I read something similar to that somewhere but I'm afraid of blowing the ballast. No need for any of there adapters or wiring harnesses?
puckhead
CO
Nah, just swap em and you should be good. happened to me, nothing blown and they are still running strong
DaRosa218
The Dude abides
Modesto, California
thats the problem on most HID sets, just reverse, you'll be golden.
Ditto, I had the same problem. I have 10,000K slim ballast and they're awesome :mexsmoke:
Daylight
Nighttime
mharders
Just outside of Seattle
Same here, just installed mine sun night. Didnt work so switched them around and now loving my HID's also installed some yellow 880 bulbs in the fogs
oakrdrs187
Coachella,CA
Ever Been Shocked by a WET ballast??
Kind of Therapeutic actually...
The Real problem is when you plug in to the stock connector. You should always used the harness that came (at no extra charge) supplied with the ballast, then determine with a test light which is you're positive and negative (on the car) and match the correct side to the HID. Black ground, blue or red positive.
Installation with a relay would be optimum BTW.
HeavyHoe03
