riso79
So Cal
Started the tedious task of dynomating the truck. 1 door down, 3 more to go then the floors and side panels.
solored
canada
Got a mobil1 oil change, engine flush, and some lucas fuel injection cleaner, runs pretty good... Got my ujoint changed out on the rear of the transfer case... wow all i can say is that the one that came out was gernaded!!! got lucky, and thankful I got it changed when I did, rides way better lol...
put in 3 10" jl audio w0's, sounds good and clean. Still might add the other 2. too lazy to build a box though, so maybe just upgrade to some bigger 10"s. need to dynamatt a metric shit ton though... rear climate controls just bounce.
solored
canada
Argh, i cant wait to lower the kon after winter... HATE SNOW AND SALLLLLT!!!! alllways washing, and hoping the roads will stay cold, and not sloppy and wet and slushy!!! DAMN SALT !!!!
summmer where areeee you!!!
solored
canada
Well got rid of the esky 18" wheels, and went back to the 16s wrapped in new wrangler authoirtys (walmart brand!! haha) they are actually a great tire, and I needed something more agressive for work! plus made 100$ on the 18s!
jdpber
GOLD MEMBER
The America
Install new fuel filter. 10 minute job.. now both banks are running proper and not throwing a lean error code....
Mr.Martin
NC
This happened a few weeks ago but I got the rear wiper shaved off.
Physh1
I did the "big 3" upgrade. Stuff has been sitting here for weeks & finally just got around to it. Didn't take long...about an hour...
I used JL audio top posts, 1/0 welding wire, & soldered on cable lugs.
Cameron
chacho44
MOTORCITY
Froze my ass of in 12 degree weather but installed 02 esky steering wheel, took the yukon to repair the tab that popped off my rear glass for the defroster, installed 04 door mirrors only with turn signals, still need to be wired to to work.
---------- Post added at 08:56 PM ---------- Previous post was at 08:55 PM ----------
Big 3 the cheapest/easiest electrical upgrade you can do.
What is this mod, and whats point of it
Tahoewhat
Ballin' on a Budget
TX
Bought finally my Billet Grille and LED Side marker lights
Pics of leds? when you get them in.
Finally got my tahoe aligned after installing drop spindles. Tires wear out fast, or i just drive to much. Now need two tires. :emotions122:
solored
canada
cmmmmon on now that aint cold!!!!
ASG-MikeS
