I want all your ideas/fixes for the seat heater SHUTTING off dilemma!
wade
I have an 03 Denali. Had it for 2 years, not an issue ever with this. As of this week, the seat heaters in BOTH front seats like to just randomly shut off.
Whats the beef?
TnTahoe
TN
i believe the heating elements have gone bad, mine is just in my drivers seat tho, the passenger works fine but when i turn the driver seat on it will shut off the passenger seat too
03YukonNH
Manchester, NH
Theres a thread on here somewhere on how to replace the heating element in the seat. Apparently they short out and corrode over time - probably from getting wet from getting in and out in the rain or snow. Anyway, theres a thread that shows what they look like and how to replace them with pictures.
W
wade
damnit. I replaced the lower (ass) heating pad. no fix.
the seat will stay heated all day, but once i move or bounce my ass around, it shuts off.
W
wade
I am STILL fighting this. The pass. seat heater works great.
But now the driver, it wont even stay on. Once I press the seat heater button, it shuts off immediately. I have a new ASS heater pad, door seat heater switch and a new brain(mother board) that is under the seat in place and STILL the seat shuts off.
I guess I will order the back heating element pad and try that.
Joe1129uscg
I have repaired lots of these and its always been the upper heating element...
W
wade
I am stumped on how to get the back section of seat off to check that pad. Can you guide me on that
Joe1129uscg
I was too...I just reached under the leather and pulled the heat pad out and then WITHOUT removing the paper from the sticky get it into position and then pull the paper off the sticky strip. You will need to take the entire seat out to do this, not as hard as it sounds there are four bolts that hold the seat down.
Joe1129uscg
Dorman brand- Orielly Auto Part or Amazon
641-105 Lower
641-106 Upper
W
wade
I must be failing, i typed it in at oreilly, no luck
---------- Post added at 05:20 PM ---------- Previous post was at 05:17 PM ----------
it worked for the lower pad, not the upper..
Joe1129uscg
I typed it in and found both of them on the Orielly site. Make sure you upper pad is bad before you order it.
Rivieraracing
I think the upper was mistyped!! I think he meant 641-106
Rivieraracing
So, those part numbers will only work in '03 - '06 trucks, do you know what the #'s would be for an '02 by chance? I'm getting close to taking my drivers seat out to figure out whether mine are bad!
Tribalbreak
WARminster PA
funny thing wade, me and you always have similar problems at similar times... I have the same problem except mine randomly turn on then when i turn them off come right back on... seems only to do it when its wet outside, so im going to guess my issue is switch and moisture related.
Rivieraracing
So it was the upper pad after all?
---------- Post added at 06:06 PM ---------- Previous post was at 06:04 PM ----------
We saw the pic for the upper you pulled out but what did the lower one look like when you pulled it out?
W
wade
the bottom pad was slightly burnt, but the upper was TOAST. I recommend everyone replace both. My seat now is AMAZING
Phlipnstik
