How to clean dried wax on black plastic trim?
ramrod
MD
I'm sure most of us run into this---- spending hours detailing and then a few days later finding out you touched some black plastic trim while you were applying the wax. What is the best way to remove it? I've tried Mother's Back to Black with limited success.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
If all else fails try duplicolor trim paint. It matches perfectly and it super easy to apply. I do all my fenders every 2 months or so.
R
ramrod
MD
You serious? never heard of that. Hmm, maybe it'll be PB and J for lunch mixed in with some experimenting on trim!
DTAILS
Black Wow works very well on ANY type of trim ......... easily removes wax build up.
Copland
Germany
To remove wax spots from the rough surfaced plastic trims, you can try to rub it away with a soft rubber/eraser. It's an easy and cheap way to deal with it. I'm not kiddin... It really works, have done it for several times by myself. greetz
DTAILS
+1 .... even with the older vehicles this is a great method to permanently remove the "white" from the black.
Mothers Back to Black
Temporary at best. Anything that you apply to hide a blemish will eventually come off.
vsaravia
