IDK, I ordered 1/2ton rotors. I havn't seen or read anything about using 3/4ton rotors on our trucks, and I didn't want to be the first. hehe.
Yes, technically you are correct. The pedal will travel down more on 3/4ton calipers than 1/2ton calipers....when using cheap pads. You won't like it. However, when offset by the Hawks thicker pads, you will like it. That particular combo works for me. It feels better than when I started, which is what I was after.
Honestly, I didn't find much of a difference in price in calipers sizes. A few bucks at most. The 3/4ton calipers were one of the cheapest componants. And to answer your question, Yes. IMHO it's worth it. When those Hawk pads heat up and start to grab, you can really feel it, and I actually have to back off the brake pedal. That could be the pads, could be the calipers, rotors, who knows. But I really like this combo. Makes me wish I had done this earlier.
No need to apologize man. That's what this place is about. Helping someone until they are happy with the answers.
I think that much like shocks, braking is a personal experience. We can talk about it for some time, but eventually you'll have to take the plunge and try it. And let's say that for what ever reason, you don't like it. Your only out less than $80 for a set of calipers, and an afternoon to swap the 1/2ton back in. You can reuse all your other new parts, then sell your 3/4ton set here. That's the cool part of running these trucks. Most mods can be reversed easily and cheaply if you don't like em.
---------- Post added at 07:25 PM ---------- Previous post was at 07:22 PM ----------
Hey, I was just curious, are you in a position to measure new OEM 1/2ton pads thickness?
It will take more pedal travel to move the pads the same distance using the 3/4t calipers. The additional volume due to a larger piston requires more brake fluid. Pad thickness makes no difference in the distance the pad moves to contact the rotor.
The 3/4t pads being used have a greater surface area increasing pad contact area probably had the largest impact here.
Think of it this way, does it take longer to inflate a larger balloon with the same amount of PSI air source?
Best bang for your buck: Pads, rotors, calipers. If your lines are old, replacing them is a great upgrade.
---------- Post added at 12:57 PM ---------- Previous post was at 12:24 PM ----------
I can't find the link now, but someone mentioned the 3/4 discs were the same size as our 1/2 ton, but were "thicker"
Additional Info: The discs for the K2500 (i.e 3/4) are 8 lug and I believe our 1/2 ton are 6 lug
I guess you are talking about the rotors.
There are 6 lug 3/4t. The GVW is 7200lbs on them instead of 8600lbs.
As for the size of the rotors? The 6 lug 3/4t seems to be the same as the 1/2t
I misunderstood you in your thread, I thought you pulled those off and switched to cheapie 1/2 ton pads temporarily until you recieved the correct Hawk pads.
