Escalade Tail Light Swap
zach2011
Platinum Member
I just missed out on a set on eBay for $60. They were in perfect condition and OEM! The only other bidder outbid me at the very last 5 seconds. :emotions122:
White07Tahoe
New Orleans, LA
Do the lights stick out at all? Are they the same shape as the stock lights? I want to do this but it looks like they stick out a little at the top.
zach2011
Platinum Member
If you keep the stock pillars above the tail lights, they do, but if you get the Escalade ones they kind of match the shape. Not really a noticeable difference though, unless someone pointed it out.
zach2011
Platinum Member
I LOVE THEM. My favorite mod, they look stock and work very well. I like the looks with the Escalade 3rd brake:
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The Esky tails are shaped differently from the Yukon/Tahoe appliques, but it is less noticeable than you'd think... IF you look at it from the top or bottom it can be seen, but otherwise the difference is minimal...
zach2011
Platinum Member
YES, glad you still have those pictures, they are a really good reference for Escalade tail fitment.
vntgspd
SoCal
Just thought I would throw this out there...
I bought the correct harness to install the Denali light into my Tahoe from an online Chevy Dealer for $24 each. Plug and play - took 5 minutes to change both lights. The Escalade harness was the same price.
By this time you buy the adapters in this DIY, I'm not sure that you save much time. Just food for thought...
Nice write up for those that have the time and want to save some $$$. :waytogo:
felixgun
Lafayette, LA
Does the 3rd brake light come with the painted piece on it? I was looking at my tahoe on how to remove that 3rd brake light and it looks it is just one main screw. Is the painted piece on the tahoe brake light attached to the removable led tahoe 3rd brake light?
Desert Driver
Saudi Arabia
Great write up, I've been looking for something on this subject for quite a while. However, the edge that sticks out has thrown me into turmoil now as to whether or not to do this mod.
73shark
KC, MO
Welcome to the forum.
You have two options, one is install the Esky applique which has the matching square corner or get a set of Eagle Eyes which match the OEM Tahoe contour. They are also plug and play.
burbanpeter
wiring diagram for escalade tail light swap?
the pictures of exconn has been removed, can someone show me how to wire up the escalade tail lights to my 2011 suburban? does anyone have pictures of the wiring diagram?
---------- Post added at 07:54 PM ---------- Previous post was at 07:16 PM ----------
can someone show me how to wire up escalade tail lights on my 2011 suburban since the pictures has be remove from this forum
TXDENALI
Is there a harness that can be bought to by-pass all this wiring? If so does anyone know the part numbers?
This would be to put Esky tails on my '10 Denali
Brace
