Seafomin my hoe but i gotta a question for yall
Drgnblood
F%ck Douchebagistan!
Douchebagistan for now
is this the main line to my brake booster.....it looks like it runs down to my power steering resivoir...so where is the vacum line??? and srsly 5 views and no responses....come on guys
tom q
Modesto, CA
I just bought a seafoam the other day but haven't used it yet. In an 04, I believe the correct hose is behind the engine (driver's side), near the spark plug.
Please correct me if I'm wrong coz I also want try the seafoam. I saw a thread on this in TF and Z71 forums
Drgnblood
Drgnblood
Ok....finally got back around to it.....the vaccum hose is underneath the vortec cover....unscrew that and on the throttle body...the silver box looking piece that is behind your intake manifold their is a rubber hose connected...when you pop it off you should hear your engine bog down a bit....thats how you know you have the correct hose...i didnt get a big smoke show....actually i got very little smoke..... and i was a little dissapointed but oh well...
Grocery Getter
A guy with a truck.
Phoenix, Az
U r right, there is a hose that runs from the TB down to the block. U want to take the hose off the block on the passengers side and put the seafoam in so it is sucked right into the TB. If u have someone give the gas pedal a rev it will work better. Instead of sucking it u can also just pour it in the hose.....
HMFDZ28
Hunt Sta, NY
just for the info it looks like you have a hydraboost brake system... aka no vaccum line.
tybardy
everyone needs a Hoe
Gilbert Arizona
yes it is on the passenger side right at the throttle body, its the biggest hose in the area (not the coolent hose obviously)
make sure you remove the hose from the BLOCK not the THROTLE BODY... it wont hurt either way but it wont work if you do it wrong.
Drgnblood
Drgnblood
i pulled it off the throttle body....had no issues but didnt see alot of smoke either....
tybardy
Gilbert Arizona
yes you wont have any issue, seafoam is nice because its really pretty harmless when it goes into the wrong areas and always makes its way out.... you may want to buy another can and do it the other way, you will probably get more smoke.
Drgnblood
Drgnblood
i will do it on the next oil change.....i figure i just ran the RP oil in and will do one more change before i leave it in there for 12000 mi
rossida
