How to turn off your daytime running lamps (DRL)
ravingmadman
Chief Knuckle Buster
Greater Seattle
I know it became a big topic on TF, so i figured i'd bring it over..
dudeface
calgary canada
so what.................I remove it, repalce it, just unplug it
WTF
PEACE
nevermind...........got it figured out
double peace
TahoeJim
SE Ohio
It took me 4 minutes to pull that diode and 2 of that was me getting comfy on the floor with the pliers and flash light.
That versus pulling the fuse (and I wasn't 100% sure if DRL was isolated or something else shared that circuit) I'd rather have one less piece of garbage under the instrument panel.
loulblades
Western PA
DRL fuse on mine is also fog lights. Since I didn't have factory fog lights, I pulled the fuse.
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
If I ever want my daytime lights off I just press my E-Brake down a click. It's enough to flip the switch but not to actuate the brakes.
But why does it matter if your lights are on during the day any ways?
Landchipper
AL
I just do not like running the charge on my alternator and the bulb hours for nothing.
My ride is big enough to be seen and if I need to turn the lights on I want to do it.
h0tr0d
Brenham, Tx.
For those who care: If you don't have factory fog lights.
Locate the fuse panel on the drivers side of the dashboard near the door. Remove the 20A fuse #15 marked "DRL / Fog" on the infographic.
Done...annoyance averted.
the big blue bus
richmond, va
i have no fuse there... and thats where i pluged my cb in. i have no lights on during the day time im confused as to what drls are
h0tr0d
Brenham, Tx.
DRL= Daytime Running Lights
Basically your low-beam headlights are on ALL the time as soon as you turn the engine on...which makes it really hard to hide from people at night ;)
Apparently, pulling the fuse doesn't work for everyone as stated by bowtiefreak, but it worked great for me.
Devious_Tahoe96
Mr. Budwieser
West Texas
hotrod said:
Basically your low-beam headlights are on ALL the time as soon as you turn the engine on...which makes it really hard to hide from people at night[\QUOTE]
Thats how you lose the cops at night lol 2 lefts and a right, pull into a driveway with your lights off and just put it in park and watch them pass you while they decide "which way did he go?" haha priceless
the big blue bus
richmond, va
i mean i know what they are but im not sure if i have them? do all the tahoes have em?
Devious_Tahoe96
Mr. Budwieser
West Texas
I believe so. Best way to check is on your cluster. If there's a high beam indicator thats green when you turn on the truck and the e-brake is released, it should be on. If not check your fuses. IMO
corbyone
South Florida
I know this is an is a kinda old thread but I just pulled the fuse tonight after installing some HIDs and it worked for me to. 1996 Tahoe LT 4d 4wd...
raptorforme93
Tampa, Fl
Do all tahoes have DRLs?? If so my hoe came with them undone and they only turn on by switch now. My hoe also came with that stupid ass buzzer that goes off when your keys are in the ignition and everything :)
h0tr0d
Brenham, Tx.
I'm not sure if they all did, but my '99 SLT did. Unfortunately my yukon has a broken window motor, so pulling the buzzer module was more of a necessity for me since I'm too lazy to drill out all those rivets right now. If you haven't done it already, look up under the dash by the steering wheel and yank out the black plastic box that's about 1.5" x 2.5" that's plugged into the fuse block...no more buzzing...EVER! Search for "buzzing" on the tech info obs threads if you need a picture.
AdrienR
