Blizzardx23's Pick-n-Pull thread
BlizzardX23
BlizzardX23
Sacramento, California
Heres stuff from the yard....
This is from ONE Denali
These are from a DIFFERENT Denali
Avalanche Midgate
A couple Tahoes
ecordell
CordellDesigns.com
Merica
Could you check on a cluster from a denali? See how much one would cost.
dropmech
Puddle Pirate
Coral Springs
Bliz, yes I can put the brackets in. All Tahoes came predrilled. My holes are filled in with plugs I have to remove. Also, how much for that grille? Are any of the grills Silver Birch?
andrewmoore13
can you look for an '03+ dash bezel and radio cage? preferably for a denali with the dark wood grain trim.
possibly an escalade cluster/lens (lens is preferred)
ghost
Senior Member
ill take you up on that all white grill shell if know one is interested allready!
---------- Post added at 03:28 PM ---------- Previous post was at 03:25 PM ----------
also on the center console i cant find a good pic.. but one like the one in your boy Kaseys hoe!
AquinoSteven
Key and Spacer Guru
Clinton, NJ
If its not too much trouble.
2000-2006 LT fogs with the male/female plugs or
2000-2006 Z71 lower valance with fogs and plugs.
I prefer the Z71 but ill the the LT fogs if it too much trouble.
THANKS A TON!!!!!!
thehoe92
fo sho
The916
Blizz!!! next time you go take me I got a whole list of things I need to get
particularly a hub assembly so I can get an alignment!
BlizzardX23
BlizzardX23
I check the Denalis and see how much they are....what year do you need?
I'll scoop up those brackets for you, I'll check on another grill, but I dont believe theres any more painted grills...just chrome
In the Denali there, the dash bezel is gray..not woodgrain, but I can pull out the radio cage and set it aside if you want? and wait for another Denali to come in? or I can get you a regular dash bezel...but thats probly what your trying to upgrade from
*Currently, the yard is out of Escalades*
I will keep my eye out for more, but I found that one for acbaseball5...however, there are a bunch more grills though...just not in white
I'll get the pricing...it is dirty, maybe a little scuffed, I'll take a rag and clean it up next time I go out there and take a look at it..
THANKS A TON!!!!!!
I'll check on those for you next time I go out there...this next week
lq4 6.0!!
if possible motor wiring, and pcm.
You want one of those LQ4s? or just the wiring and pcm?
BillBlatt18
Latham, NY
do they have the gmc logo from the tailgate of a denali? and how much would a running board be? it has to be one of the ones with the seperate end caps. post a pic if u can. Thanks
Huck
Whut Thee Huck?!
San Diego
I need something like this near me. i don't need anything specific, but it would be nice to just go look...
KrautBurner
Bremerton, Wa
***** - I just got my window switch from a gray avalanche, so I'll check on the mid gate
The third row...you have pictured a NNBS...newest style...you want those? or you want 00-06 style? This is where I got my 3rd row from
Also, I'll check on the rims too....
NBS - 00-06
(the pic was just the first thing I found)
---------- Post added at 08:54 AM ---------- Previous post was at 08:48 AM ----------
Mounting brackets for 3rd row seat (DO YOU HAVE A PLACE TO BOLT THEM?)
price please ;)
---------- Post added at 08:56 AM ---------- Previous post was at 08:54 AM ----------
Avalanche Midgate
price please
---------- Post added at 08:58 AM ---------- Previous post was at 08:56 AM ----------
I believe this 3rd row is from a LWB: Yukon XL / Suburban
Tahoe/Yukon 3rd row should be two pieces
---------- Post added at 09:00 AM ---------- Previous post was at 08:58 AM ----------
I can also use a 00-02 Tahoe LT Left side Fog Light
and the cubby pocket in the dash where the ONSTAR goes
(to the right of the climate control)
and the climate controls (front and rear)
mine are celcius
BlueTahoe2001
Charlotte, NC
Blizzard, Can you check on a set of Electric fans, OEM Harness, and the brackets for me? Im assuming that the 03+ Years had E-Fans and those should work in order to swap those into my 01'?
Thanks
ScottyBoy
Shreveport, La
Thanks
Actually, they never put E-fans in anything until 2005. So all the 05-06's should have E-fans. I'd like to know what they charge for E-fans as well. :Handshake:
ghost
Senior Member
if they have older body style 90's tahoes, burbs, or eskys, i could use a set of sway bar end links as they are shorter than the ones on our trucks and in whiteouts thread a cheaper solution to the aftermarket endlinks.
tom q
Modesto, CA
left fog lamps PLEASE. The glass broke and the reflector piece melted.
Blizzard I'm in Modesto. Where do you get the parts? I could probably go there one weekend.
---------- Post added at 12:23 PM ---------- Previous post was at 11:44 AM ----------
Avalanche Midgate
A couple Tahoes
Oh and the rear radio controls too. Mine broke
BlueTahoe2001
Charlotte, NC
Thanks man! I as never sure what years they came in, and I know the 03's had some different things done to them but no completely sure what.
vsaravia
