Pic Request for OBS
danken12
Could someone please post a picture of where you hooked up your A/C override on an Efan setup? If not a pic, then please explain which wire and what color it is, and where you hooked into it.
Thanks a lot.
wicked2000
El paso TX
Are you looking for the wire that turns the fans on when the AC comes on? Hopefully you are not using the set up I used because it did not work for me.
D
danken12
What exactly didn't work for you?
But yes, my fans are pretty similar to what you have there in the pic. I have the fans working, but only with the thermostat probe. No override is hooked up right now.
wicked2000
El paso TX
It overheats after a while driving in the city with AC on. Mine come on when the AC is turned on or thermostat kicks them on.
---------- Post added at 01:38 PM ---------- Previous post was at 01:35 PM ----------
I had these on my 95 silverado for two weeks and did not work. Rag got caught on my fan while wheeling the tahoe so since i had these lying around I thought i would try them on the Hoe but no luck.
D
danken12
so which wire did you use to hook into the AC unit? I couldn't tell from the pic?
My fans are dual 2100 CFM fans. I think they'll do ok, but we'll see for sure after a few days of driving.
wicked2000
El paso TX
Let me know how they work for you. Its the green one.
briannorris
