l.e.d. cluster
01burban
springfield,missouri
i have a 01 suburban and want to do white leds in the cluster, any clue by what bulbs and how hard it is to do? any special tools or soldering to do... i couldnt find any threads thanks.
Thumper8302
OKC, OK
they are 194s... just pop ur dash trip off and unbolt the cluster then twist out the bulb socked and swap out the bulbs.. quite easy.. maybe 20 minutes of work if it ur first time
alxs210
Reno, NV
diffrnt
Say...What!
MS
It won't turn out white. There is this blue film on the cluster and I don't think anybody has figured out a way to remove it. If you use white leds, it will still be blue. I know, because I have tried it.
Brick
Boca Raton, FL
Here is mine in blue, ****** phone pic but what i got at moment
01burban
so from what ive read, it takes 6 or 8 194s and white will still make it look blue .. and it is pretty easy nothing to solder in . just plug n play pretty much?
alxs210
Reno, NV
01burban
solored
canada
just a matter of putting the cluster back in and seeing what lights work and what lights dont work.. i know with the lights i got off ebay they will only work installed the right way(just have to take them out and plug them in the other way) but other then they are bright.. so how is it that factory 194 bulbs are white, and you still get a white look on the face... though you go to LED and then its blue?
diffrnt
Say...What!
MS
This is what I've noticed. The factory bulbs are halogen and have a slightly yellow look to them. If you look closely at your cluster, it's not actually just pure white, it has a greenish tint to it. So yellowish factory bulbs + blue film = light greenish cluster. I painted over the factory bulb with blue paint and the cluster turn totally green. It was king of cool, but didn't match up with the rest of my dash.
TejasPitt
