4th Gear issue after rebuild
DemonicDonut
Hello all, I'm hoping one of you wizards can save my bacon.
2010 Yukon SLT 5.3 LMG
I recently did a rebuild on my 6l80. New torque converter (local TC shop, billet and high carbon clutch), sonnax zip kit, transgo shift kit, transgo unbreakable ring kit, sonnax slide pivot pin, new bell housing, pump stator, tehcm seals and diaphragms, pioneer rebuild kit (all but steels)
I didn't disassemble clutch drums as I don't have a good press to reassemble, so I didn't replace the seals on them. I air tested all pistons but maybe I didn't don't right?
I'm having an issue intermittently with 4th gear.
When shifting into 4th under low load (~30pct throttle) the shift will attempt but flare and go back down and repeat until the CEL comes on and P1751 - shift valve performance code is in the trans. I have what seems to be called "busy shifting"
I have a HP tuner MPVI3 and have some logs I can attach soon that I recorded when the issue was happening.
When it does the flare, I can let off of it and sometimes it will shift but the shift time is very high (1 second or more)
It will also do this when in 5th and downshifting into 4th with light throttle.
I've played with TCC lockup and shift pressures, which seems to have helped but it's still happening at times.
I've pulled the tehcm and valve body off. Opened it up, cleaned everything really well and made sure everything was assembled correctly, check balls in place etc. I used the correct gasket for my valve body year.
I didn't ohm the solenoids though, which I'm kicking myself for now.
The main weird thing is the intermittent aspect. It was bad and I adjusted pressures and it seemed to be resolved for over a week. We towed our TT to the beach and it did the busy shift 1 time out of 4 hours of driving on the way there. I adjusted oncoming and off going pressures slightly as well as shift pressures (slightly increased low load section of tables) and on the way home it never had a problem.
The next day it did it to my wife and I played with programming again, it drove fine for me afterwards and now it happened to her again.
I'm at a loss for what it could be, unless the adaptives are taking too much pressure out of the 3-4 and 5-4 shifts over time. But towing was perfect?
Is there something in the programming I need to change with the new TC or parts I changed out?
Any help would be great. Feel free to ask questions. I'm working but have a slow day and will check here throughout the day. I'll be adding the logs as soon as I can.
Thanks for the help.
D
DemonicDonut
I'd like to note as well that this is a new issue, and wasn't present before the rebuild. I wanted to rebuild due to mileage (192k now) and some occasional harsh shifts and shuddering TC. The shifting has been very smooth other than these flares and the TC shudder is gone.
I'm trying to upload the files but they aren't supported. Do I need to upload to dropbox or Google Drive etc and share the link?
NickTransmissions
Sin City
The transmission bench
I have a feeling you're going to be going back into the transmission to replace all of your piston seals/bonded pistons as that should have been done to begin with. You'll need to purchase the tools or bring your drums and new parts to a shop who will do it for you. Did you replace the turbine shaft seals?
Also, is the TEHCM brand new? If not, I'd replace it with an OEM GM TEHCM as well as IMS and speed sensor harness assembly for your vintage. Call the the dealer, speak to 'Parts' and provide the last eight digits of your VIN. They will sell you the TEHCM you need.
I usually don't mix Sonnax and Transgo components in these transmissions. Typically, I install the Zip kit but occasionally will use the Tow-N-Pro. Not saying this is the problem but I'd pour over the instructions for both kits again (if you haven't already) and see if there are any potential conflicts w/combining anything.
One other diag step, before taking the pan off, is to thread in a line pressure gauge, take readings at idle then drive it with the gauge installed (some folks will tape the gauge face to the wind shield so they can monitor pressures while still keeping their eyes on the road). If you see a pressure drop when shifting into 4th in normal 'D', no Tow Mode', you have a leak in the 4th gear apply circuit somewhere.
The only other thing I'd try is a full adaptive reset / programmatic reset to bring back the factory tune. You should have zero flare shifts at any throttle angle, road speed or driving situation if everything is mechanically sound in the transmission with a stock engine and factory program.
D
DemonicDonut
I appreciate the input.
The kit I bought said it came with rubber molded pistons but it only came with seals. so I replaced everything I could without disassembling the pistons completely. I didn't want to last minute
Do you have a recommendation on a kit? Do I need to buy a full seal overhaul kit and replace everything again? Or can I get just the bonded pistons and related orings and seals?
I did replace the turbine shaft seals.
I'll try the gauge and full reset back to baseline before I pull the trigger on parts.
Originally all I changed in programming was shift scheduling and TCC lockup points and slip speeds. Would any of those theoretically cause this?
NickTransmissions
Sin City
I’m not a tuner so can’t really answer your specific tuning questions however @BlackBearPerf may know if those changes are potential causes (I’m thinking no but don’t want to just guess outside my lane).
If the unit has to come out, replace all bonded pistons, piston seals, gaskets, seals between the VB and case / pump if those weren’t already replaced as well as the TEHCM (OEM GM) and anything else like the HD parking rod assembly that wasn’t already replaced.
Also check your 456 drum for leaks at the spin welds, if you haven’t done that already. Same with the 35R drum - make sure it’s not leaking at the welds between the clutch basket and center section.
MWD_CTSV
I would agree with Nick, don't mix the Transgo and Sonnax kits. The Sonnax is really a superset of the Transgo except for the switch diaphragms and the stator sealing rings (which or only for 2006-2009). If you used the Transgo stator rings, I would switch back to the factory style non-rotational rings.
I have never used the Pioneer kit, but if the frictions provide a clutch clearance is in spec that should be fine. I would never skip a 4-5-6 apply piston upgrade on a 6L80 rebuild because that is a known weakness. Sonnax provides two versions, either using the original 6 clutch stackup or a modified 7 clutch high capacity version. The 4-5-6 apply piston that you skipped because it requires a press, is the primary element in the 3-4 shift, because that is when it engages.
Messing with the pressure switch seals and diaphragms is the one thing I would not do again unless there was an existing or obvious problem. I feel like that process is more risk than reward, especially on the later units, and I'm pretty sure that is a big reason why Sonnax no longer provides them in their zip kit. Pressure switch problems often manifest as shift flares.
I would definitely start with the TECHM reset as Nick suggests and re-evaluate.
D
DemonicDonut
I reset programming and it's performing worse than before.
A strange thing I noted after I made some more adjustments and before I reset to the factory programming - 4th would shift fine, but once in fourth if I increased throttle to a point that the TC would unlock, the TC would unlock, rpms would start to rise (maybe 100 rpm) and it would start doing the busy shift flare to 3k, drop to ~2400 rpm over and over. It's really bizarre and I don't understand it. I wish I knew more of the programming/logic of these computers.
I'm buying new bonded pistons, a new separator plate with baked on gasket from GM and a new TEHCM. However GM wants $1500 for the TEHCM. Sonnax and transtar remans are ~$350.
I know the canned answer is new OEM is best. But is the risk really that high with getting a reman from sonnax etc?
The local GM parts guy was really helpful and was trying to cut me a break where he could, he quoted me $4200 (+2000 core) for a brand new transmission. If I go with the GM TEHCM for $1500 I'm going to be in it for $4000 so far and that's a hard pill to swallow when I could need the 4/5/6 apply as well. And who knows what else.
I've really opened Pandora's box here and would have been better off with a new transmission from GM to begin with.
Why don't you like the transgo stator rings?
I was pretty meticulous and zip locked all parts together as I went, I'll look and see if I have the zip kit valves and springs still, I may have tossed them all when I cleaned up though.
Conedaddy
