steering wheel
Z-56 Hoe
What do I do????
Houston
I want to put a 2008 steering wheel with controls on my 2001 I have a Z-3 head unit can / will it mount up, and also will / can I get the controls to work?
Z-56 Hoe
Z-56 Hoe
What do I do????
Houston
will it mount tho? and if so would it look ok? mine is ten years old with a lot of Highway miles so long peirods of time with hands on the wheel. also is ther no way to splice the wires to make it work?
Boomer73
Boom Boom
Crownsville, MD
Given that GMT900s are GMLAN and GMT800s from 2003-2006 are Class II data bus, I doubt there is a way to splice it.
-B
thor1125
orange county
will not work at all.. you can maybe get away with updating it to a 2003 and up steering wheel with controls, but there is some work involved....
ILLEGAL REGAL
Tinley Park, IL
I was looking into this... I believe you can get it to work on an aftermarket radio using the 07+ clock spring and wire it up yourself. However I do not believe the airbag plugs are the same.
I've changed my mind on that setup and am either going to run a 03+ base model wheel or get a half leather/wood 01 wheel or a billet wheel.
chip
Cincinnati
What about in my '03 Yukon? Anybody know which steering wheel I can run in this?
chip
Cincinnati
Thanks Timmy! Do you know if I can put on a wheel with stereo controls, and will it actually operate the stereo as well?
---------- Post added at 08:46 PM ---------- Previous post was at 08:45 PM ----------
BTW: Your truck is sick!
Timmy
Brunswick, GA
Timmy, you seem to know... whats different in the airbag plug from an 02 to and 03?
00-02 use a stage one style bag, 03+ use stage 2.
actually, i have a clock spring for sale right now... you need to change the clock spring and steering wheel and have the BCM programmed by the dealership.
Before you ask, the clock spring is the coil that's in the steering column that allows the wires to turn without binding up or breaking. It's not hard to install AT ALL.
The BCM is the "brain" of your yukon. it sends signals for EVERYTHING you do.
shoot me a text if you have any questions regarding the interior of these trucks. 912 294 7207.
i've taken my truck from WT to LT so, i know a thing or two. ;)
chip
Cincinnati
Hahaha! Yeah, I've done a few builds myself.
Thanks for the offer, and the info, but IMO it's not worth the effort. I'm just gonna get a nice DD with a remote. I've been wanting to do a dvd & nav system anyway.
Good lookin' out on the #. I may actually use that when I finally get around to pimpin' the inside.
Timmy
Brunswick, GA
and, if you go dd, i just got the new kenwood ddx-516. i love it. if i had to do it agian though, i'd get the dnx-9140
chip
Cincinnati
Checkin' out now. Thanks!
---------- Post added at 09:14 AM ---------- Previous post was at 09:12 AM ----------
I like it!
Timmy
Brunswick, GA
it's pricey, but worth it. are you doing the install yourself because i have my stereo guy that'll give you a decent price if you want.
AdrienR
