Suburban died and won't restart (but sometimes it does...)
P
project_x
I haven't been driving it.. because I would like to not get stranded.. but I keep starting it, running, and moving around my property... Hopefully it stalls or won't start to figure it out
60 psi running seems like a lot more than the normal ~43 psi that most of these run with the engine running.
But help us out -- or did I miss that info -- year, make, model, engine, and is it Flex Fuel, or gas only?
LsHart
Senior Member
55 to 62 psi. Both ways. Damn that is crazy. For sure was thinking one was lower as usual. Compared to the 04 tahoe L59 flex.
P
project_x
Now, I'm not sure what else I can do until I get it to stall/not start...
LsHart
Senior Member
Whe ur used to working on urs and a LM7 pops up.
LsHart
Senior Member
I would step out and say that if it does a first try no start just turns over, but it does start on the second try, then look at cam sensor pigtail and or sensor correlation. That's where I would start off at.
LsHart
Senior Member
She is getting plenty of tackling fuel!
Agreed, but I think these will run without the cam sensor. Might have long crank time, though.
Easiest first thing to try is clear flood mode. You know, while you're sitting there and it's not starting.
jkhuntzinger
