Fuel Level Sensor Nightmare
OtsegoAmigo21
Hi everybody!
So this year I purchased a 2010 chevy tahoe and its been a Rollercoaster with it since...
The last remaining major issue that we cannot seem to figure out.
We switched out the fuel pump but I had happened to get the wrong guy the day I ordered my fuel pump and he ordered the AC delco pump without the fuel level sensor... unlike we discussed.
Im just a parts manager, my husband is the mechanic. I wasnt there when he swapped the pumps and when he saw that the level sensor wasnt with the pump, he put the old one on it.... had it seen that it wouldve been a full stop.
It keeps reading at 0 and is triggering a code, id have to ask my husband what it was, but it basically states its unable to read fuel level
I got a new sensor thinking maybe theyre incompatible. Still wont work.
Has anyone else had this issue that could maybe give me some insight? I love my tahoe... but im ready to scrap her for all this trouble. My poor husband has dropped the tank three times already. Hes stumped. We both work with GM mechanics, theyre stumped.
mikez71
O
OtsegoAmigo21
Looking at the last diagram on this page...
It looks like the sensor should read 40ohms when full, 250ohms empty.
I'd check the resistance of the sender, and if it is within range, then the problem is elsewhere..
(possible wiring issue?)
Thank you, ill look into that! It just strikes us as odd that everything worked perfectly fine until we switched pumps
rdezs
I would get a new ACDelco or Delphi fuel pump with the sender.
The one you ordered may not have the wiring up to the plug that included a sending unit. And test the resistance of it prior to installing.
What model number is the pump that's been installed?
And what RPO codes does it have starting with "L"?
O
OtsegoAmigo21
Thats what I've been afraid of.. I gave him the number for the one I have and he said it technically didn't match my tahoe and it didn't have the sensor so I told him to get me the Delphi one, not a problem. Ive just heard some unfavorable things about the Delphi ones even though they're technically the same thing. I just didnt want to be in the same spot as I am now in a couple months. I didnt think to check it when they dropped it off, lesson learned. Ive had issues with this guy for the simplest things like emery cloth and drain pans. Nice guy, but lord getting correct things from him is like pulling teeth some days. This is going to be fun conversation with their manager on Monday. I cant even put the old one back on, it had the typical line rot on the top and they crushed to pieces when my husband took it off.
O
OtsegoAmigo21
Im going off memory, the invoice is on my desk at work its like mt100095 I believe
The code its throwing now is P0463 says its reading too high
Drwinlied
Ive had issues with this guy for the simplest things like emery cloth and drain pans. Nice guy, but lord getting correct things from him is like pulling teeth some days. I cant even put the old one back on, it had the typical line rot on the top and they crushed to pieces when my husband took it off.
Must be the same guy that put my pump in last year lol.
Capybarbro
