21 Yukon XL Service TPMS System?
Litsnsirn
Two days ago the service TPMS message came up on my Yukon and the front tire pressures weren’t displayed any longer. Today I tried doing the TPMS relearn and I wasn’t able to get the front sensors to beep. After some driving around, the rears stopped reporting so all four tires aren’t showing readings. It seems strange that I lost two and then pretty rapidly, the other two. It doesn’t seem like all four sensors would quit at roughly the same time, so are there any modules that could cause this?
I had the service TPMS message come up, and both rear wheels stopped showing pressure reading on the DIC. I tried several relearn procedures, and they all failed. Turned out that the battery in my rear right TPMS sensor was dead, and the sensor we replaced. Issue resolved.
Deno
Disconnect your positive from the battery and reconnect after 5 mins, relearn the drive for 20 miles.
L
Litsnsirn
Is there a way to read the voltage of the sensors?
5 years seems a bit premature but could maybe depend on your driving habits and gm being cheap which would not be surprising at all.
rotate the rear tires to the front and see if it those read even temporarily if so then probably looking at new tpms sensors which is roughly $200 depending which tire shop you visit, some may be more thirsty than others.
L
Litsnsirn
After much procrastination, i disconnected the negative terminal, because I couldn’t figure out how to lift the positive terminal off after loosening it. I let it sit a half hour, and after reconnecting the service TPMs popped up immediately and three of the four tires had no response the fourth one got a beep, but the display didn’t ever show anything. So, the only thing that really happened is that I had to go through the window relearn procedure and I’m in the same position i was beforehand. My scan tool seems to not have anything about the TPMs in it. Is there a sweet spot for scan tools with the most functionality for price that will give me the readings?
L
Litsnsirn
FWIW, the negative cable should always be the one that's disconnected first.
I agree, it’s just one of the replies above told me to disconnect the positive. I am a telecom engineer and i got into that, originally, by being an emergency vehicle upfitter. The first thing we did when a car was about to get worked on was disconnect the negative terminal.
jkhuntzinger
