New Tires for 24” Factory Wheels
white15
Hey all! I looked around the forum 1st before posting and couldn’t find much info. Trying to go a little wider on tires than my stock size 285/45R24 but I don’t want to sacrifice any side wall…. Has anyone done this yet? If so hows your experience? Picture of My SUV attached.
Thanks all!
I did a quick search, and I found only 1 tire, an off-road tire, in the 295/45x24 size ($500+ each). I found no tires in the 305/45x24 size. You may be SOL with your increased tire width desire at the 24" wheel size.
KMeloney
Thanks all!
Along with tire availability limitations, I think another issue you'd have to contend with is tires is wider tires rubbing on fender liners and/or components (and that you'd have to make some modifications to accommodate the added width).
Try sniffing around in the "Lifted" section. Some folks in there have gone with wider tires (and explained the mods they needed to make) -- but some of them have also gone with wheels with different offsets. Not sure you'll find anyone with wider 24"s in there, but maybe -- and if the tire heights remain the same between 22"s and 24"s, then you can still get some useable info there, I'd think.
2024 White Tahoe
Thanks all!
Why do you want to get wider tires?
Thanks everyone so far! Just for look purposes, i feel like the tires just look a bit skinny/narrow for how big of a vehicle it is… again not looking to go real wide… just a tad bigger than stock….
I totally understand.
wwiizz
