Eibach Front shock install question
Zarati
I am installing Eibach shocks on my 07' Yukon. I chose them ooverv 5100s simply because they are supposedly a little softer while still firmer than stock. Very similar design though , and utilize the same grooves for adjustable lower perch. Extended length is about 3/4" longer than stock. Should allow similar droop to stock even with 1.25" lift.
Rears installed quick and easy. Front , I'm running into issues getting the lower mount up onto the control arm. Because of the extra length ot just doesn't clear. Sway bar is disconnected but the upper control arm is bottoming out on a part of the frame that looks like it is designed to act as an extension stop.
Has Anyone else run into this issue with other installs? I can drop a control arm to make it fit. It just surprised me As I hadn't seen anyone else mention that.
Thanks
mikez71
Sounds like you need to undo upper balljoint.
Hammer outward on the knuckle to pop it loose if stuck.
I've always had to undo mine (z71 strut) and to install lift spacers.
Dirty looks
Is the collapsed length of both shocks the same? That part on the frame is indeed an extension stop. Upper control arms designed for a lift will allow more droop. Rough country for example.
Some lift kits require removing that stop. A limiting strap would be recommended at that point.
Z
Zarati
Thank you. After reading some threads on spacer installs, I tried a long piece of pipe placed under the bottom spring coil and over the top of the knuckle and pressed down, and that was enough for it to pop in place. Just barely, I think if I went for the tallest groove, I would have needed to pop the ball joint like you said.
Z
Zarati
That's a good question. I did not measure the compressed length but I haven't done the other side yet. I will now measure, as I would like to know as well.
Z
Zarati
If anyone is curious , I did measure them. Fully compressed , they are the same length as stock shocks. Fully extended they are about one 3/4" longer.
After putting about 500 miles on them, I am also very happy with them. I am one notch down from the top, Which according to Eibach , is about a 1.4" lift , and I am perfectly level with a full tank and a couple hundred pounds of gear in the back of my rig. I put them through their paces a bit at speed and they soak up large frost heaves and bigger bumps way better than I had expected. Around town , on our bumpy residential streets , they are very supple and feel very stock like. I feel like they are the best of both worlds so very happy.
ScottS-Michigan
