mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,339
- Reaction score
- 4,140
So I have no codes for evap, but evap monitor has not set.
I notice my fuel tank pressure is not smooth if purge valve is not either fully open or fully closed.
Tank pressure (yellow) fluctuates about .45V if purge valve (green) is not fully open/closed.
Starting FTP voltage is 1.50V.
One log showed 1.56V after evap vent opened at startup.
HPTuners has the vent position backwards..
(read that voltage should be 1.3-1.5V)
Normal pressure spikes? Or defective valve or clogged line/canister or?
I was thinking the PWM purge might have a restriction in the line.
Purge valves are cheap, so I ordered one. (Along with new gas cap and vent valve for now)
Not saying this is the reason monitor has not set, just looking for clues.
If anyone can log theirs (maybe @strutaeng
), or can explain what I should be seeing,
it would be much appreciated!
Have also considered a small leak could be messing with the cooldown fuel tank pressure reading..
), or can explain what I should be seeing,it would be much appreciated!
