All, I have a '13 LT with 205K miles. As far as I know, the shocks all around are original and long overdue for replacement. I've had it for 6 years and intend to keep it about another 10 years. So, I was going to order parts and swap them out. However, after much reading, I found the RPO data plate in the glove box. I have the ZW7 code for Premium Smooth Ride suspension. There are also 6RN and 7RN, which I think are related to the front shocks.
I was doing work on the charcoal filter and got the part no. off the rear shocks while I was under there. The are marked OE 17124 and 2281184. Did not have time to look at fronts to try and find part numbers. But, I did confirm with the rears that I do NOT have any kind of "air shocks" or an air pump.
I was hoping to find affordable coil-over assembly for the fronts and OEM replacement for rear. I Googled the 2281184 number and see GM OEM replacements for about $75 each.
But, what about the fronts? I've seen recommendations for KYB, but all of the ones I find have fine print that specifically exclude the ZW7 code. So, I'm hoping one of you experts can point me to a supplier/part no. Locally, I have Advance Auto Parts, Auto Zone, OReilly's and NAPA. Or, I can order online from most anywhere.
What should I get for the fronts -- but please provide the website and specific part number.
I have found plenty of videos for swapping out the coil-overs on the fronts. But, if I'm forced to just do the interior strut, does anyone have a link to a video showing how to safely remove the coil. I can purchase a coil compression tool for $30, and can do that, if needed.
Many thanks in advance.
