just out of curiosity
07burban88
hypothetically speaking. if one had another gmt900 and it had no motor, but one had a sbc 350. how hard would it be to swap said 350 engines into gmt900, specifically a 09 Tahoe. was browsing FB and found an all-black Tahoe, hole in the block
mountie
Hypothetically, replace it with a same 5.3. Save the HEADACHE !!
SpareParts
North Idaho
It could be done and a unique option. Why not go with a 454? You just have to work through each problem as you go. This what i can think of for potential problems.
Motor mounts. Fairly easy.
Flex plate. I'm sure someone sells an adaptor kit.
Trans controller. Would need an after market controller Around $500.
Exhaust.
Might be a job all in itself to get dash gauges to work.
If carbed a different fuel system setup.
How to hook up the gas pedal.
Oil pan not a problem if you need a different style.
Power steering pump hose fittings might be different sizes. Easily solved.
Alternator hook up. Easy
Ignition. Easy
Everyone is gonna be against it but i think it would be a cool fun project. How cool to pop the hood and see a nice big chromed rat engine under the hood!
mountie
Exhaust.
Ignition. Easy
I agree……. I responded if he just wanted the Tahoe to run. BUT….. If he wants a project to modify the Tahoe, that would be cool !
SpareParts
North Idaho
If i still had a 454 sitting around i would be all over doing it. 350 would not cut it for me though as i would only do it to a Yukon XL, Suburban, Escalade ESV.
Plenty of them around with bad engines or trans under 2k in otherwise decent shape.
hypothetically used 5.3's are in abundance, short block and off you go
all you have to do is get one from a matching 8th digit vin
make doesn't matter it's plug-n-play, you don't even need the ecm or anything.
when you go to a shop and ask about putting a used engine in they turn around and call the junkyard, how much for a vin F or a vin T, or a vin R
they just go by the 8th digit in your vin. matching vin motors slap right in
GMT800 2005 Tahoe Z71
Navy Supporting Member
Do a stock 5.3 and do a Black Bear Tune and put money in the transmission for longevity. No AFM of course.
SpareParts
North Idaho
It's really up to you and what you want.
It can be done for sure. If you are doing all the work yourself cost is not bad. Just time effort and some parts and a little fab work.
If i could not do the work myself i would never do it as it probably would cost a lot! I can do it all the work my self and bet it would be under 1.5k and i got the time.
No matter what any of us say it's up to you. It's your stuff so do what ya want. That's how we get custom cars and car shows.
If you do it, please don't do a half as* job and actually make it something you want people to see.
a1parrothead
