Power Steering Hose Replacement
EddieC
The pressure hose on '08 Tahoe power steering is oozing a bit. If changed out, I suspect air will get in the system.
Is that difficult to get out?
GMT800 2005 Tahoe Z71
Navy Supporting Member
There are several videos to watch on this. When hose installed, lift front tires off ground, refill slowly and with engine off turn steering slowly-stop to stop. Take your time and do not rush. With system full, set back on ground and start engine and again, turn very slowly. Add fluid as needed till stays full while still turning slowly, stop to stop. Then cap off and road test and recheck fluid level.
I just ran across a video that promotes using a vacuum pump.
Not necessary?
You can use a vacuum pump, no problem. My way is without a vacuum pump. I have used my way for gobs of years. The biggest mistake people do is leaving the front tires on the ground when initially bleeding.
Also, I left something out. When tires are in the air and you have turned stop to stop, SLOWLY, and topped off. Then start the engine and continue the stop to stop with engine at idle. Again, turn slowly and smoothly and continuously. Do not turn 1/8th turn and stop and then 1/8th turn again. Turn all the way, stop to stop, smoothly. Then on ground and repeat and top off as needed and then road test. It may still need a top off because it takes a while to get air out.
Any fluid fill, at any time in the process, should be done slowly.
EddieC
EddieC
"Then cap off and road test and recheck fluid level."
Open pump road test?
LsHart
Senior Member
I have replaced lines and just fill and crank. But if a rack or gear box per say, fill it and bust the lowest line loose. When drippin.. tighten and go flickin!! Lol
"Cap On....Cap Off....The Capper". If you did not know what I meant, then stay away from doing the job. Or, you are messing with me. Either way, anytime you drive, have the P/S cap on the reservoir. I mean "everybody and every cap". Clear enough????
alvocado
Allen
Cincinnati, OH
I've always bled with wheels off the ground, slowly turning the steering wheel clock to clock about 20 times and it has worked every time. Reservoir open during the bleeding. Do it slowly or you'll have a huge mess.
EddieC
EddieC
Not messing with you at all. Just wanted to be sure. Could be taken either way talking about the reservoir.
Thanks for the help.
ScottyBoy
Shreveport, La
I can give you one tip on replacing the power steering lines. Using Flarenut Crows Foot wrenches will help you TREMENDOUSLY. I've never replaced my own power steering lines, but I helped my son replace the ones on his 99 Silverado. I tried breaking the futting loose with a flare nut wrench, but I just couldn't get enough room to actually turn the wrench. Then I remembered that I had a set of flare nut crows foot wrenches. Using those allowed me to add as long of an extension as needed in order to get the ratchet in an area with plenty of room to swing it.
Like these:
ScottyBoy
Shreveport, La
Like these:
Exactly like that. But I'm too poor for that Snap-On set. I have a $30 set made by Sunex. It gets the job done just the same, but for far less money. Now if I was a professional and had to use these all day 5 days a week, then I would "maybe" consider the Snap-On set. But for a "home gamer" like myself, the Sunex set is more than adequate.
EddieC
EddieC
I actually saw a video just about the advantage of the crows foot wrenches for the job.
kikeap
