Pwtr02ss home build
mountie
Can you find a large parking lot where you use cones and chalk to mock it out and with your vehicles try real world type approach to see how large an area you need
Or, just follow Mountie's method and brake going into the turn and accelerate exiting, as you are not entering a straight away but the garage so mastering this technique may be challenging
Some one has been watching an old TV show called Batman….
pwtr02ss
pwtr02ss
Tennessee
Turning radius of a crew cab Silverado (regular bed) is about 25'. That's how I estimated the 35' depth. Was looking for real world experience with this setup. Google says 25-30' is standard, but I'm not sure that's enough.
I'd say the width of the garages at minimum. Be kinda weird being smaller and having half the garage entry grass and the other concrete
Maybe I should word it differently for you. The depth, maybe? Like, how far out from the garage is a comfortable distance to get a full size suv pulled in the garage. I've never had a side entry garage. Want to get it right the first time, without over kill. I'm thinking 35' should be sufficient.
You're having a version of a side entry, what's your planned width (or depth) to enter the bay?
tuckerrnr1
Port St Lucie, Florida
When I was starting out in construction, one of my employers tasked me to go to Palm Beach and build platforms and mockup windows at elevation so the owner could stand and look out the "window" and decide changes before we broke ground saving a lot of time and money on changes and setbacks. That's why I recommend mocking in a parking lot and use the vehicles you have to determine real world dimensions
mountie
Garage entry paint
pwtr02ss
pwtr02ss
Tennessee
Thank you for your input. I was being lazy...
If they get the shop pad graveled next week, I'll have the house footprint flagged, based on the aerial survey photos to see how it looks. From there, we'll adjust in real life. I'll be able to mark it and test it then.
I was just trying to get info from those who live it daily
mountie
Turning toward the garage door, to comfortably line up to enter, …… in photo….. position left tires at the gutter’s edge, then left turn and straighten, facing garage entry….
In photo, I measured 40’ from garage door to gutter…. then add 8 or 10 feet more distance for your drive up to driveway entry.
So, 50 feet ?
( In Google Map, the car on driveway is our Infiniti QX50.
THE YETI
Director of Operations
South FL
Ah yes. Depth makes sense now. My old house was side load. I’d have to think about depth on that but it was about 30’. Plenty for my wife to pull up, swing out, and back her suburban in. Same with my 06 Silverado crew cab.
I have not given any thought at all to our driveway since we are around 5 years out from deciding that. I’m als
Not 100% sold on our garage configuration just yet either. But we have quite a while to figure that out.
pwtr02ss
pwtr02ss
Tennessee
So, 50 feet ?
Thank you both for the input. I'm going to lay it out at 35' and see what I think. Don't want to waste, but want it to be right
mountie
The first 12 feet of the actual driveway is your turning……. into driveway... then straighten ahead to enter onto actual driveway pad. Without feeling cramped.
Especially if you park on left side.
( Keep in mind, your left-side tires will be parallel to the gutter edge ( as per photo)
Geotrash
Dave
Richmond, VA
Be sure to leave enough extra room for our Airstream to park there, too. The better for us to "moochdock" with. :p
And if you can have a 50A RV outlet, water spigot, and septic drain installed there too, that would be great! :happy175:
THE YETI
South FL
Good call. You might need interior climate controlled parking as well in case there’s a Lamborghini/Ferrari/McLaren that stops by.
pwtr02ss
pwtr02ss
Tennessee
Does the septic usually go in last?
It depends on the builder. The guy digging my footers will be the one that installs the septic. Not sure if he'll do it first or last.
Not the same guy that's done my grade work. This guy is a certified surveyor and lays out all of his jobsites, so he'll also do my staking and elevation shots, then build a gps model, using the drone imagery I posted the other day. Pretty interested in seeing how all this works
pwtr02ss
pwtr02ss
Tennessee
Nothing really got done while I was on vacation. They worked the Friday that we left, but just at the entrance. They started cutting a new swale to pull the water away from the retaining wall and redirect to both catch basins that are by the road and driveway. They also started cleaning up the sides of the driveway. There's piles of brush stacked up along side that need to be moved and burned.
I went out today while one of his guys was out there. They cut more of the hump out the pad, closest to my house. Reworking the slope closest to the catch basin. It was still pretty wet when they started today, but dried out pretty good by the time I got out there after work.
If the weather will hold out, the logs should be gone, sides of the driveway cleaned up, slopes seeded and strawed, and the pad graveled by the end of the week. He said he's going to try to have all of that done anyway. Main thing is logs moved, that small section of dirt under the logs moved, and the pad graveled. If all that's done, I'll have the footprint staked or at least flagged from gps data by the weekend. If I'm happy with it, I'll get it final staked asap.
Here's a few pics I took today. Looks the same, because photos don't really show well. Didn't take any of the front. It was getting dark by the time I left and I forgot.
I'm sure you're all as tired of looking at dirt as I am. Hopefully a change comes soon
pwtr02ss
pwtr02ss
Tennessee
Stopped by after my MRI. They got the sides of the driveway cleaned up and rough graded, but no top soil. The pile is still too wet. Grade on the pad is polished, logs are gone. Plan to gravel the pad and driveway tomorrow. Going to wait until the top soil pile dries out before we attempt that, but the main thing is gravel. I'm pretty excited and I really hope it happens.
I didn't take any pictures, sorry.
1948Buickroadie
