No R or 1st
N6812t
Hello all. I have a 2016 Tahoe 5.3 LT 2WD with 105k. Been fine so far, except for the thermostat kerfuffle which was easy to handle. This week it stopped moving (intermittently at first, to the point that I thought I was nuts because it quickly corrected) in 1st or reverse. The third time and after that required I go to M2 I can get motion and use D with normal results until the next full stop. I am not driving it this way, only done so in ‘WTF figure this out mode’ after it happened twice and to get it to a shop.
Shop says no error codes, but that it needs a valve body for $2200. Does this sound right, in both assessment and cost?
I can rebuild a Lycoming 320, 312 Y block and teapot carb, or replace the clutch and throw out bearing on an Rx7, but automatic transmissions are voodoo to me. It’s actually almost embarrassing.
Any feedback is appreciated.
NickTransmissions
Sin City
The transmission bench
Drop the valve body and check to see if the #1 and/or #5 check ball have worn and migrated out of position.
My video explains:
6L80 No Forward No Reverse Check the Check Balls #automobile #transmissionrepair #6L80
GMT800 2005 Tahoe Z71
Navy Supporting Member
My video explains:
If it is a 4L60E, is that a whole other video, or are the check balls in the same place? Is it as easy as just replacing the check balls or is a new valve body needed, like the shop said? Thanks.
NickTransmissions
Sin City
Here's a 4L60E video for a similar situation (check balls getting stuck/wearing or migrating):
Tupapi
