2018YUKONSLT
- Joined
- Jan 23, 2026
- Posts
- 54
- Reaction score
- 30
Yes, it definitely an intimidating experience when you never dealt with this but, I’ll get it done. I appreciate the feedback, so much to learn.
As indicated above, YouTube is your friend. Do a little searching, and you will find many videos with step-by-step instructions for doing the entire job, quite probably on your exact model/year truck. Just follow them step by step, and you will complete your first brake job, increased your wrenching knowledge base and skill set, and you will have saved several hundred dollars in the process.Exactly those are good points, so glad I joined this group. Can’t wait to get this truck back on to rolling
How bad is the leak? Drips on the garage floor or driveway? How much? For a very minor leak, I'd probably just let it go, until it leaks more noticeably.fozzi58, thank you for recommending ball joints to me. Also thank you for the recommendation of not getting rotors resurfaced. Good tip on shopping around for a quality mechanic? How much you think a reasonable price for that engine oil leak by the way? It’s at rear main seal housing and upper pan gasket. I am in San Antonio Texas. Thanks for any advice, I appreciate it.
Joseph, it’s a small minor leak. The service manager actually let me walk to bay. Showed me the brakes and leak and other stuff mentioned. He said brakes first, then other stuff. It leaks very minimal. But do plan to get it fixed. Thanks for your help.
The inspection is the one of the main reasons I get oil changes at the dealer. I love having someone inspect the truck for me and providing a list of needed repairs. Unless you’re regularly underneath your truck a lot of their upsells would get missed. Then just check the items off one by one until I get their next to do list.Dealers (and other shops) don’t make much money off the regular oil changes and tire rotations. They make money off of what I would consider “upselling”… that is why many shops will do free inspections. It gives them an opportunity to quote more jobs to you that they can make more money on.
I replaced my front and rear rotors and brake pads myself for about $400 and an afternoon of my time. That was also using a little bit of an upgraded brake kit. You can get kits cheaper than that, too.
I say this not to make you feel bad about spending money on a brake job, but because a dealership will throw a $6000 quote at you and it makes you feel overwhelmed, when it’s many times them trying to get more work so they can make more money.
I wouldn’t inherently ignore the dealer’s recommendations, but if you are not fond of doing your own work, I would find a reputable, local mechanic that you can trust. A lot of them may see issues but instead of throwing a bill at you, they’ll say “yeah, your front brakes are low, but you still got a year or two left”. Stuff like that.
Everybody here is more than happy to help with any questions. Many here know just about everything with these trucks and how to fix them.
