Both headlamps on passenger side stopped working
claymartin
My wife's 2014 escalade high and low beam headlights on the passenger side stopped working. We replaced the bulbs with no success. Is there a common relay or fuse that would cause both to fail? Or is there a common ground that may be the culprit?
Thank you.
GMT800 2005 Tahoe Z71
Navy Supporting Member
30 & 16 are fuses for the high beam and low beam on passenger side.
Thank you.
I forgot to ask, did you even look in your owner's manual or inside the fuse box/relay cover?
jkhuntzinger
