LOCATION OF FRONT DIFFERENTIAL DRAIN & FILL PLUGS?
EgEric
I have a 2007 Chevy Tahoe LT 2WD & I replaced the seal, that the Yoke goes into the transfer case & the drive shaft is back on, now the problem I’m having is locating the Fill & Drain plug, I’ve watched numerous videos & none were 2WD, so please someone tell me where it at, because I cannot find it??? So I can refill my gear oil??
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me on the 2WD truck will chime in.
E
EgEric
Miami-Dade
Moderator Supporting Member
@EgEric Moved you here for your questions from Site News.
Welcome from NYC Eric!
E
EgEric
E
EgEric
So if I don’t have a transfer case, was that gear oil that leaked out or transmission fluid that leaked out?
& if that was differential fluid & I don’t have a transfer case, should I replace the fluid in the rear differential?
& can I start the vehicle to check the vehicles transmission fluid, basically what’s my next thing to to get this vehicle going for my mom?
j91z28d1
yeah, 2wd doesn't have a transfer case. what you slid the drive shift yoke into, which I guess is where you replaced the seal is called the tail housing. it's part of the transmission.
a transfer case looks much different but it does bolt to the tranny in the same place as the tail housing does. it's just much larger, goes off the drivers side of the truck. and has its own fluid inside it. the tail housing doesn't. it's just a empty kinda cone shape aluminum housing straight back from the tranny.
so if it was leaking from the front of the drive shaft where it goes into the transmission. that's transmission fluid. dex 6. if it was the rear end housing, where the drive shaft bolts into the rear axle housing that was leaking. that's gear lube. 75-90w I believe. definitely don't mix those to up and put the wrong fluid in either one.
E
EgEric
Thank You so much and thank you for detailing it for me as this department is not my department, I just wanted to do it for my mother so she doesn’t have to spend the money and I got stuck and Thank You once again & Happy Holidays..!!!!!
E
EgEric
And I’ll give an update as I change out all the fluids and start her up!!!
BadDaddy2003
