fathoe
- Joined
- Aug 24, 2024
- Posts
- 12
- Reaction score
- 7
Hello, I have a 08 tahoe and this is my current setup:
Stock rear suspension besides Monroe ma830 air struts
Front has all new everything,
Ksp UCAs (0-2 inch)
Chinese no name poly Lcas
Re man steering rack
A premium cv axles
A premium tie rods
Rancho rs9999xls 2inch lift
Slotted alignment sliders 304 stainless
1.5 inch wheel spacers all around
33 (275/70/18) sentinel r/ts all around
The ranchos ride Ok, there is definitely change whenever you do adjust the dampening, but i have two main complaints.
Rancho has a tri-tube design, and therefore has amazing compression dampening, but really bad rebound dampening, so whenever you go through whoops you have to get the speed just right otherwise it will feel like a car accident over every bump.
On the softest dampening, there is none. You can feel the springs bounce, and it almost feels like you are about to figure out a “tahoe space program”.
The adjustment knob is also super stiff. I had to cycle it back and forth with pliers before it became soft again.
Another complaint that doesnt really matter is that they arent white and red, they are just silver, so if you are trying to flex your new coilovers to your friends, they arent rancho colors.
Ucas and lcas being full poly does make your ride quality a lot worse. I know that this may make me think the ranchos ride bad, but i had a rc 2 inch spacer on the stock coilovers prior to this, and they didnt ride too much worse.
The monroe ma830s ride super well when they have air in them, but you either have to have a onboard compressor or refill them daily (im constantly loaded with just short of 1k lbs)
The air lines on the air kit were standard 1/8th inch air line, if you look to do this mod yourself (my tahoe wasnt factory opted with a air system, being a lt3 i think)
Ksp makes really good ucas and spacers, ive had both for about 6-7 months now, the only thing you have to do for poly ucas is the slotted alignment plates, because the oem ones will not hold a alignment.
Ksp UCAs (0-2 inch)
A premium cv axles
A premium tie rods
