Anybody lower a 4WD?
mikez71
mikez71
Thanks for that! Will order bars soon...
Updated with 'lowered' pic. Top pic is new KYB Monomax no spacer
rest are stock 200k struts with 1.5" lift spacer.
It's funny, their website is incorrect. It shows that set you posted as fitting Escalade, Avalanche, Tahoe, and Yukon but not a Suburban... lol
Also, Autozone has them listed over $100 cheaper...
That says Autozone wants $557 on my end here. Summit has them for $400. That’s what I paid. Summit FTW!
kbuskill
NE. FL.
That is a different kit. The kit you posted is 35mm front/30mm rear.
The kit he and I posted is 38mm front/33mm rear.
The bigger kit is $674 on Summit, so Autozone FTW still.
I'm not sure if 3mm difference is enough to worry about but it must be or they wouldn't make 2 different sizes, right? Or maybe that's how they get you... lol
mikez71
mikez71
Installed the kyb monomax front struts today. I think @Rocket Man was wondering about these.
Taller for now.
Updated first post with picture. Hard to compare because I didn't measure and I removed a 1.5" lift spacer.
(Stock Z71 rear springs with 3rd row removed) The way it looks currently, I'm hesitant to install PPV rear springs.
The coil spring was about 1mm thicker and had 1 extra coil compared to the Z71 front's (stock 4WD?)
KYP top hat seems flimsier, doesn't have that edge completely rolled over.
I re-used oem strut top nuts, they had a bigger flange and did not have serrations like the ones included from kyb.
Hardly any weld holding the shock to bottom mount, but all photos I've seen look like that.
Taller for now.
I ended up going with Arnott’s As2715’s on the front t of mine. The ride is nice; they did lower the front an additional 1/2” or so from the worn-out stocks. Mine are flipped on the control arms, mounted under.
Arnott SK-2954 Front Coil-Over... https://www.amazon.com/dp/B07529VZ82?ref=ppx_pop_mob_ap_share
mikez71
mikez71
KYB feel softer than stock over bumps. I like it so far. Probably raised front .5" or so. Might still settle..
Stock was a little jarring on speed bumps in comparison.
mikez71
mikez71
Got the Nolathane bars. Thanks to @kbuskill for the autozone link. Took just 2 days.
Here's the beef! 30.8 lbs / 38mm front bar, 24.4 bs / 33mm rear bar.
Stock rear bar with endlinks and rubber bushings, 12.2 lbs. / 28mm
I'm worried these will break something! Front eyelet 5/8" thick..
kbuskill
NE. FL.
Here's the beef! 30.8 lbs front bar, 24.4 lbs rear bar.
Did they happen to tell you when the set you ordered me would be arriving?... lol
kbuskill
NE. FL.
I found the end links a bit of a challenge on the front, seemed the eye is a bit of a different angle but I got it to work- just took a bit of messing around. Damn thing was heavy.
mikez71
mikez71
Yup.. Here they are upside down..
First try I put it in the way I thought it should be.. wrong..
Second try, a lot better, not perfect.
Thinking a shorter link might be little better.
Already compressed endlink bushings made it easier to assemble..
I could see myself struggling with fresh bushings.
Driving impressions:
Truck feels more solid over bumps. Obviously corners flatter.
Lots of imperfections like cracks in the road and rough road surfaces, do feel worse.
Like micro-jiggles that would have soaked up better with softer bars..
Old Moog bushings after about 5k miles. Ovalized some, seemed fine.
Pried them apart so you can see amount of wear.
I love it! (except the crappy roads)
Don't think I want any more stiffening after 20" wheels and these..
kbuskill
NE. FL.
Yup..
Second try, a bit better, not perfect. Thinking a shorter link might be little better.
Driving impressions, makes the truck feel heavier over bumps. Obviously corners flatter.
Like micro-jiggles that would have soaked up better with the softer bars..
I love it! (except the crappy roads) Don't think I can take any more stiffening after 20" wheels and these though..
I mean, if you are going to complain about them, I guess i could take them off your hands. I don't want you being uncomfortable whilst driving your truck.
Marky Dissod
Have you tried simulating any emergency lane changes yet?
mikez71
mikez71
Not yet. I haven't hit the highway, but also I need to do alignment.
Going to try my toe plates, tomorrow? I need more neg camber on driver side just eyeballing sidewall up to the fender edge.
Sadly, I did not perform an emergency lane change before, so I will have nothing to directly compare to.
Tight cornering over bumps feels like the back might tend to skate. Will it feel balanced?
Truck definately feels better suited to higher speeds and quicker turning.
That was my first impression when I had it installed with the long end links and it wasn’t parallel to the control arm. Install shorter links; the road imperfections you feel will be unnoticeable. As far as using new bushings- I take the big washer off and use a regular washer just to get the thing compressed, then disassemble and reassemble with the correct big, cup washer. It’s a cheat.
mikez71
mikez71
Good tip, thanks! Yep I ordered some 2-3/8" vs my old 3" (sleeve length)
Want to lower the back, but the ppv rear springs are only 13" long. Stock z71 shocks allow ~16" at full droop..Installed height ~12". So the PPV springs might lower too much, depends how much they compress..
If they compress 2" would be about right.
Should I get shock brackets used for lowering? 2" would put droop length at 14", ppv spring with rubber pads would be right around that length..
Yes you’ll need shock relocation brackets before the rear. In used 2” ones. If the PPV springs lower it too much you can add a puck under them.
mikez71
mikez71
Small update, went to 2-3/8" energy suspension endlinks. Stock was about 3" (spacer length only).
before with newer delco endlinks.
after with ES 2-3/8" links
Looking like 2" might be better still.
The ES links use standard bolts with 9/16" socket size.
If installing Nolathane bars, one should assume shorter endlinks will be needed as Rocketman mentioned.
justinakay79
